[Qgis-user] editing shapefile attributes
Zoltan Szecsei
zoltans at geograph.co.za
Sun Nov 10 02:34:16 PST 2013
Ah!
Too cool - thanks.
Regards,
Zoltan
On 2013/11/10 12:31, Richard Duivenvoorde wrote:
> On 10-11-13 10:50, Zoltan Szecsei wrote:
>> Hi,
>> I have a shapefile open in QGis 2.0.1
>> Is there a quicker way to select a graphic element (say a point) and
>> edit/update its attributes?
>> I am currently selecting the point, opening the attribute table,
>> scrolling down until I see the hilighted row, editing the fields, then
>> closing the attribute table and deselecting the feature.
>> Seems a bit tedious so hopefully there is an easier way.
> Yes:
> 0) select the layer you want to edit attr from
> 1) put you layer in 'editable' mode
> 2) go to menu: /Settings/Options/Map Tools (on Linux, on windows not
> sure. You have to have the general options dialog)
> 3) check the second checkbox: "Open feature from, if a single feature is
> identified"
> 4) select the identify tool (i-tool)
> 5) now click on the feature you want to edit: a form will show in which
> you can change the values of the attr, of THAT feature
> HTH
> Regards,
> ps (as an extra) in the properties dialog of the layer itself, you can
> in the item 'Fields' even create your own form
Zoltan Szecsei PrGISc [PGP0031]
Geograph (Pty) Ltd.
P.O. Box 7, Muizenberg 7950, South Africa.
65 Main Road, Muizenberg 7945
Western Cape, South Africa.
34° 6'16.35"S 18°28'5.62"E
Tel: +27-21-7884897 Mobile: +27-83-6004028
Fax: +27-86-6115323 www.geograph.co.za
