[Qgis-user] R: Re: R: Re: Add table excel and categorize
labiancamarilena at libero.it
Tue Nov 12 10:00:05 PST 2013
thanks a lot.
I've solved the problem.
CSV is indeed recognized as a string but I downloaded Quantum 2.0 and with
some tricks, the system allows to graduate values .
When I import CSV use " Custom delimiters " in this way successfully it loads
the file.
Thank you very much!
>----Messaggio originale----
>Da: bernd.vogelgesang at gmx.de
>Data: 12/11/2013 16.35
>A: "labiancamarilena at libero.it"<labiancamarilena at libero.it>, <qgis-user at lists.
osgeo.org>
>Ogg: Re: R: Re: [Qgis-user] Add table excel and categorize
>Am 12.11.2013 16:01, schrieb labiancamarilena at libero.it:
>> Hi,
>> yes the file is a csv (which has numeric values).
>Check the csv properties within QGIS -> Fields Tab: See if your fields
>are really interpreted as integer/real values and NOT string!
>Cause when this is string, the values can't show up for classification.
>When you use 2.0 (at least), you might have better luck importing the
>csv through Layers -> Add delimited text file instead of drag-and-drop
>into the ToC.
>There QGIS tries to guess the field type.
>This might fail as well, cause your original excel sheet might have
>wrong data. A very popular bug are spaces in front or behind your numbers.
>You should search and delete them there.
>There is also the possibility to create an affiliated csvt-file (see
>http://anitagraser.com/2011/03/07/how-to-specify-data-types-of-csv-columns-
for-use-in-qgis/),
>in which you define the field type for the csv. But this is a very
>tiresome work when you have lots of fields.
>So, lots of speculations from my side. But we'll see ...
>Cheers
>Bernd
>> The layer to add this csv is a shapefile (its table of attributes contains
>> cod, name, lenghts of municipalities).
>> I joined them and infact the table of attributes shows the name of
>> municipalities, lenghts...and corresponding values.
>> I saved it (ESRI Shapefile) and when I select the "Style" to graduate the
>> values, the column shows only the cod. of municipalities, shape leng and
area.
>> Can you help me?
>> Thanks a lot
>>> Data: 11/11/2013 21.45
>>> A: <qgis-user at lists.osgeo.org>, "labiancamarilena at libero.it"
>>> Ogg: Re: [Qgis-user] Add table excel and categorize
>>> Hi,
>>> 1.
>>> adding a csv is not the same like loading a shape. So you can't edit it.
>>> Loading as dbf should give you write permissions (OpenOffice/Libre Office
>>> still offer dbf support, while new Excel versions don't)
>>> 2.
>>> I assume you joined the csv to an existing layer? In QGIS 2.0, the joined
>>> columns are presented for classification, in 1.8 you will (i think) have
>>> to make the join permanent by saving the joined layer to a new one. Then,
>>> all attributes are editable as well.
>>> Hope I answered your questions
>>> Bernd
>>> Am 11.11.2013, 19:53 Uhr, schrieb labiancamarilena at libero.it
>>> <labiancamarilena at libero.it>:
>>>> Dear all members of list,
>>>> I have to add a table in excel that contains indices calculated for each
>>>> municipality.
>>>> I turned the sheet from excel to csv and added to the table of
>>>> attributes as usual, but I have two problems:
>>>> 1.
>>>> Some data (indexes) when combined (the table with common code and other
>>>> attributes)
>>>> appear with the word
>>>> "null", I can add them manually? When I try to add them by editing the
>>>> appropriate line, but the program does not save the changes.
>>>> 2.
>>>> When I want to customize the style,
>>>> ie I want to categorize the classified data (they are many) and I do not
>>>> know how to reduce or customize intervals. When I try the option
>>>> graduated the values joined (indices) to the table (municipalities) do
>>>> not appear in the column.Thanks.
>>> Bernd Vogelgesang * Siedlerstrasse 2 * 91083 Baiersdorf * +49-9133-825374
