[Qgis-user] R: Re: R: Re: Add table excel and categorize
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Wed Nov 13 07:30:14 PST 2013
Am 12.11.2013 19:03, schrieb labiancamarilena at libero.it:
> Excuse me.
> I forgot. I'm reading an manual, what about GRASS to load this data?
> Thanks.
Boohaa. Never faced something less intuitive like GRASS handles data
(Think that's something for the pros). But when you manage to do so
successfully, the better.
I think the normal way to import as text delimited file should do it, or
use the before-mentioned option to save your xls as dbf and just drag
and drop.
P.S. Reading manuals is veeery good (I never do that ;) )
>> ----Messaggio originale----
>> Da: labiancamarilena at libero.it
>> Data: 12/11/2013 19.00
>> A: <bernd.vogelgesang at gmx.de>, <qgis-user at lists.osgeo.org>
>> Ogg: R: Re: R: Re: [Qgis-user] Add  table excel and categorize
>> Hi,
>> thanks a lot.
>> I've solved the problem.
>> CSV is indeed recognized as a string but I downloaded Quantum 2.0 and with
>> some tricks, the system allows to graduate values .
>> When I import CSV use " Custom delimiters " in this way successfully it
> loads
>> the file.
>> Thank you very much!
>>> Da: bernd.vogelgesang at gmx.de
>>> Data: 12/11/2013 16.35
>>> A: "labiancamarilena at libero.it"<labiancamarilena at libero.it>, <qgis-
> user at lists.
>> osgeo.org>
>>> Ogg: Re: R: Re: [Qgis-user] Add  table excel and categorize
>>> Am 12.11.2013 16:01, schrieb labiancamarilena at libero.it:
>>>> Hi,
>>>> yes the file is a csv (which has numeric values).
>>> Check the csv properties within QGIS -> Fields Tab: See if your fields
>>> are really interpreted as integer/real values and NOT string!
>>> Cause when this is string, the values can't show up for classification.
>>> When you use 2.0 (at least), you might have better luck importing the
>>> csv through Layers -> Add delimited text file instead of drag-and-drop
>>> into the ToC.
>>> There QGIS tries to guess the field type.
>>> This might fail as well, cause your original excel sheet might have
>>> wrong data. A very popular bug are spaces in front or behind your numbers.
>>> You should search and delete them there.
>>> There is also the possibility to create an affiliated csvt-file (see
>>> http://anitagraser.com/2011/03/07/how-to-specify-data-types-of-csv-columns-
>> for-use-in-qgis/),
>>> in which you define the field type for the csv. But this is a very
>>> tiresome work when you have lots of fields.
>>> So, lots of speculations from my side. But we'll see ...
>>> Cheers
>>> Bernd
>>>> The layer to add this csv is a shapefile (its table of attributes contains
>>>> cod, name, lenghts of municipalities).
>>>> I joined them and infact the table of attributes shows the name of
>>>> municipalities, lenghts...and corresponding values.
>>>> I saved it (ESRI Shapefile) and when I select the "Style" to graduate the
>>>> values, the column shows only the cod. of municipalities, shape leng and
>> area.
>>>> Can you help me?
>>>> Thanks a lot
>>>>> Data: 11/11/2013 21.45
>>>>> A: <qgis-user at lists.osgeo.org>, "labiancamarilena at libero.it"
>>>>> Ogg: Re: [Qgis-user] Add  table excel and categorize
>>>>> Hi,
>>>>> 1.
>>>>> adding a csv is not the same like loading a shape. So you can't edit it.
>>>>> Loading as dbf should give you write permissions (OpenOffice/Libre Office
>>>>> still offer dbf support, while new Excel versions don't)
>>>>> 2.
>>>>> I assume you joined the csv to an existing layer? In QGIS 2.0, the joined
>>>>> columns are presented for classification, in 1.8 you will (i think) have
>>>>> to make the join permanent by saving the joined layer to a new one. Then,
>>>>> all attributes are editable as well.
>>>>> Hope I answered your questions
>>>>> Bernd
>>>>> Am 11.11.2013, 19:53 Uhr, schrieb labiancamarilena at libero.it
>>>>> <labiancamarilena at libero.it>:
>>>>>> Dear all members of list,
>>>>>> I have to add a table in excel that contains indices calculated for each
>>>>>> municipality.
>>>>>> I turned the sheet from excel to csv and added to the table of
>>>>>> attributes as usual, but I have two problems:
>>>>>> 1.
>>>>>> Some data (indexes) when combined (the table  with common code and other
>>>>>> attributes)
>>>>>> appear with the word
>>>>>> "null", I can add them manually? When I try to add them by editing the
>>>>>> appropriate line, but the program does not save the changes.
>>>>>> 2.
>>>>>> When I want to customize the style,
>>>>>> ie I want to categorize the classified data (they are many) and I do not
>>>>>> know how to reduce or customize intervals. When I try the option
>>>>>> graduated the values ​​joined (indices) to the table (municipalities) do
>>>>>> not appear in the column.Thanks.
>>>>> Bernd Vogelgesang * Siedlerstrasse 2 * 91083 Baiersdorf * +49-9133-825374
