[Qgis-user] Profile from vector point along a straight line
venerio giuseppe anardu
anardu.geol at yahoo.it
Tue Nov 19 06:57:54 PST 2013
I knew and already used that plugin: I have several points on a surface and in that case it suits my purposes because I interpolated the vector points to obtain a DTM raster to use the plugin.
But in this case I'd need a way to accomplish the task directly from surveyed vector points without interpolating: in other words a profile made by vector points not by interpolated raster surface.
I've made some esperiments, but interpolate a raster surfece from points surveyed on a straight line, as I supposed, gave unacceptable results...
Giuseppe
Il Martedì 19 Novembre 2013 15:29, Alfonso Flaquer <alfonsofla220 at gmail.com> ha scritto:
Hi Guiseppe,
In Qgis 1.8 exist a plugin named Profile Tool. This plugin allow you to create a topographic profile from a raster layer. Maybe you can create a raster from your vector data.
regards
Hola Guiseppe,
En Qgis 1.8 existe un plugin llamado "Profile Tool". este plugin permite realizar un perfil topográfico a partir de un archivo raster. Quizás puedas obtener un raster de tus datos vectoriales y luego utilizar el plugin.
Saludos
2013/11/18 venerio giuseppe anardu <anardu.geol at yahoo.it>
Hello to everybody,
>I have to make a topographic profile of some vector points surveyed along a straight line, wich is the best way to do it?
>Many thanks in advance,
>Giuseppe
>_______________________________________________
>Qgis-user mailing list
>Qgis-user at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/qgis-user
AfLa
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131119/1fd07800/attachment.html>
