[Qgis-user] Distance calculation Matrix
    Jonathan Moules
    jonathanmoules at warwickshire.gov.uk
    Wed Nov 20 04:20:05 PST 2013
Hi Sergio,
I ended up getting the SAGA one to work by re-starting QGIS.
The one you're referencing was the first I tried and gave me either no
output or any indication anything had been done, or a Python error.
Apparently it has been fixed in master though.
Thanks,
Jonathan
On 20 November 2013 12:08, Sergio Vignali <vignalisergio30 at gmail.com> wrote:
> Hi Jonathan,
> there is another tool,
> did you try with Vector -> Analysis Tools -> Distance matrix?
> Regards
> 2013/11/20 Jonathan Moules <jonathanmoules at warwickshire.gov.uk>
>>  Hi List,
>> I have a collection of ~2,500 points in British National Grid. I want to
>> calculate the distance between all of them to all of them.
>> QGIS 2 has two tools for this as best I can tell:
>> Processing -> "Distance matrix"
>> Results:
>> - "Linear" matrix type: Nothing happens whatsoever. No errors, no
>> outputs, nothing. The dialog just disappears.
>> - "Standard" matrix type: I get a wall of Python error message:
>>> Traceback (most recent call last):
>>> File
>>> "C:/PROGRA~1/QGISDU~1/apps/qgis/./python/plugins\processing\core\GeoAlgorithm.py",
>>> line 150, in execute
>>> self.processAlgorithm(progress)
>>> File
>>> "C:/PROGRA~1/QGISDU~1/apps/qgis/./python/plugins\processing\algs\ftools\PointDistance.py",
>>> line 98, in processAlgorithm
>>> self.regularMatrix(inLayer, inField, targetLayer, targetField, nPoints,
>>> progress)
>>> File
>>> line 178, in regularMatrix
>>> data.append(unicode(outFeat.attributes[outIdx]))
>>> TypeError: 'builtin_function_or_method' object has no attribute
>>> '__getitem__'
>>  Summary: Absolutely nothing happens again
>> There's also a SAGA tool "Distance matrix". With this one I get an error
>> like:
>>  The following output layers could not be open
>>> Distance Matrix Table:
>>> C:\Users\jmou1\AppData\Local\Temp\processing\cb88ea8b51994f1cbfe5549465bc949f\TABLE.csv
>> Despite it being a location I can write to. That's using the temporary
>> output. If I specify an output location myself, I get the same error.
>> So basically, it's not working; can anyone advise what I'm doing wrong?
>> How do I use these tools? I've got three different failure modes here,
>> which isn't very encouraging.
>> Cheers,
>> Jonathan
>> This transmission is intended for the named addressee(s) only and may
>> contain sensitive or protectively marked material up to RESTRICTED and
>> should be handled accordingly. Unless you are the named addressee (or
>> authorised to receive it for the addressee) you may not copy or use it, or
>> disclose it to anyone else. If you have received this transmission in error
>> please notify the sender immediately. All email traffic sent to or from us,
>> including without limitation all GCSX traffic, may be subject to recording
>> and/or monitoring in accordance with relevant legislation.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Sergio Vignali
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131120/791b9d4f/attachment.html>
