[Qgis-user] Cannot create issue (was: raster artefact in composer pdf export)
Michael Spencer
spencer.mike.r at gmail.com
Wed Nov 20 04:28:59 PST 2013
Hi Richard,
Thanks for the steps. I suspect I'm a different Mike, or my memory is
getting worse...
I think the stumbling block for my osgeo user creation is the userid. I'm
currently trying spencermr, as I'm guessing the userid is the same as a
username and it's something I can assign. Or is the userid the same as the
user id assigned to me when I registered for the osgeo wiki?
Ta,
Michael
On 20 November 2013 10:07, Richard Duivenvoorde <rdmailings at duif.net> wrote:
> There is a (very concise) text here:
> http://www.qgis.org/en/site/forusers/support.html#issue-tracker
> which is working for me :-(
> After creating an Osgeo account (of which I'm pretty sure Mike already
> has (if he is the mike I know :-) ), you can 'just login' at qgis with
> your osgeo account (which if you have not 'registred' yet with QGIS will
> add you to our 'shadow list of users', giving us the opportunity to add
> some user related info/permissions).
> So the right track would be
> 1) create a new osgeo user if not already done:
> https://www2.osgeo.org/cgi-bin/ldap_create_user.py
> 2) use THAT username/password to login at QGIS
> via (http://hub.qgis.org/projects/quantum-gis/issues)
> https://hub.qgis.org/login
> if this is NOT working, please let me know what your (osgeo/qgis) userid
> is, I can look it up in our user list.
> And if the text is not clear enough, please take some time to make it
> clear (an email to me or community list is ok). As
> http://www.qgis.org/en/site/forusers/support.html#issue-tracker should
> be clear and working.
> Regards,
> On 20-11-13 09:31, Radim Blazek wrote:
> > See below the difficulties to create a new issue. Can somebody comment?
> > Radim
> > On Tue, Nov 19, 2013 at 3:13 PM, Michael Spencer
> > <spencer.mike.r at gmail.com> wrote:
> >> Hi I've been trying to report an issue/bug, as requested. The
> registration
> >> process is a very long way from straight forward.
> >> I found this page with instructions (no links from qgis home pages,
> found
> >> via a search): http://hub.qgis.org/wiki/quantum-gis/Bugreports. The
> option
> >> for creating an OSGeo account doesn't seem to work (the link works but
> the
> >> process fails, with no explanation why).
> >> I've tried to create an account via https://www.osgeo.org/user but the
> only
> >> options are to login or request a new password, not register a new user.
> >> I've set up a OSGeo wiki account, but this doesn't work either.
> >> Can somebody point me in the right direction as life is too short for
> this
> >> much faff!
> >> Ta,
> >> Michael
> >> On 15 November 2013 10:48, Radim Blazek <radim.blazek at gmail.com> wrote:
> >>> I am able to reproduce it with reprojected raster, the dashed lines
> >>> appear on original raster extent border. Until we fix that, the only
> >>> solution I see is to save reprojected raster and use not reprojected
> >>> raster in composition.
> >>> Please create the issue anyway.
> >>> Radim
> >>> On Fri, Nov 15, 2013 at 11:29 AM, Radim Blazek <radim.blazek at gmail.com
> >>> wrote:
> >>>> On Thu, Nov 14, 2013 at 6:33 PM, Michael Spencer
> >>>>> Hi all,
> >>>>> Just updating a figure I originally produced in v1.8 without problem.
> >>>>> The
> >>>>> aerial photo now generates a dashed line (top and bottom) artefact
> when
> >>>>> I
> >>>>> export to pdf.
> >>>>> Example here: http://ubuntuone.com/5OmDksQ5O8ppjAX4172ctl
> >>>> Please create a new issue and attach a small raster + project with
> >>>> comosition reproducing the problem.
> >>>> The raster is reprojected?
> >>>> The raster is using resampling?
> >>>> Radim
> >>>>> Any ideas how to fix it?
> >>>>> Ta,
> >>>>> Michael
> >>>>> ps copyright to appear in figure caption ;)
> >>>>> _______________________________________________
> >>>>> Qgis-user mailing list
> >>>>> Qgis-user at lists.osgeo.org
> >>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131120/d8500e26/attachment.html>
