[Qgis-user] How can I use a jpg of map as base layer & then ensure GPX waypoints match up
Michael White crwban681 at yahoo.co.uk
Wed Nov 20 20:59:12 PST 2013
Thanks Carlos and Alex. Both sets of advice were great. The key was to use georeference & set control points; so now when scrolling I do get correct lat/long on map.
I'm still doing something wrong as my waypoints don't show on map. They are correct in layer attribute table. I'm still experimenting with layer types (GPX, CSV, etc). I'll get there.
Mike
Dr Michael White
Marine Zoologist
Tongareva Atoll
Northern Cook Islands
Member of IUCN - Species Survival Commission:
Marine Turtle Specialist Group
>________________________________
> From: "qgis-user-request at lists.osgeo.org" <qgis-user-request at lists.osgeo.org>
>To: qgis-user at lists.osgeo.org
>Sent: Wednesday, 20 November 2013, 23:07
>Subject: Qgis-user Digest, Vol 93, Issue 42
>Send Qgis-user mailing list submissions to
>To subscribe or unsubscribe via the World Wide Web, visit
>    http://lists.osgeo.org/mailman/listinfo/qgis-user
>or, via email, send a message with subject or body 'help' to
>You can reach the person managing the list at
>    qgis-user-owner at lists.osgeo.org
>When replying, please edit your Subject line so it is more specific
>than "Re: Contents of Qgis-user digest..."
>Today's Topics:
>   1. Re: Shape file points not appearing in 2.0.1 (Andreas Neumann)
>   2. How can I use a jpg of map as base layer & then ensure    GPX
>      waypoints match up (Michael White)
>   3. Re: How can I use a jpg of map as base layer & then ensure
>      GPX waypoints match up (Alex Mandel)
>   4. Re: How can I use a jpg of map as base layer & then ensure
>      GPX waypoints match up (Carlos Cerd?n)
>   5. Re: Shape file points not appearing in 2.0.1 (Daniel Kranich)
>   6. Re: Shape file points not appearing in 2.0.1 (Daniel Kranich)
>   7. Cannot create issue (was: raster artefact in composer    pdf
>      export) (Radim Blazek)
>   8. Re: install qgis 2 in ubuntu 13.10 (Stefano Masera)
>   9. Re: install qgis 2 in ubuntu 13.10 (Jos? Pedro Santos)
>  10. Re: Google earth KLM files (Jos? Pedro Santos)
>  11. Qgis working or dead? (magerlin)
>  12. Re: Cannot create issue (was: raster artefact in composer pdf
>      export) (Richard Duivenvoorde)
>Message: 1
>Date: Tue, 19 Nov 2013 21:23:06 +0100
>From: Andreas Neumann <a.neumann at carto.net>
>Subject: Re: [Qgis-user] Shape file points not appearing in 2.0.1
>Message-ID: <528BC8AA.1040904 at carto.net>
>Content-Type: text/plain; charset=UTF-8
>Hi Daniel,
>Can you share this particular shapefile and the corresponding qml that
>shows the problem?
>Did you try to load it into a fresh project, not re-using the old
>project? Can you load into an empty project?
>Andreas
>Am 19.11.2013 19:02, schrieb Daniel Kranich:
>> Hello,
>> I have been using Qgis for about a year and a half now. I just upgraded
>> from 1.8 to 2.0 and have run into an issue with one of my shape files.
>> I have a shape file that is a point layer which has been working fine
>> and displaying fine in 1.8. When I open the layer in 2.0.1, The symbols
>> no longer appear on the map. The attribute table still has all the data,
>> and If I select one and pan the map to that selection, It zooms in to
>> where that particular point should be but the point is not visible on
>> the map.
>> I have checked out the symbology and there is no reason for the points
>> to not show up (checked transparency/size etc). I also tried removing
>> the layer, and re-adding it and the same problem occurs. I have also
>> double checked that it is the top layer and should be rendered on top of
>> everything else, and I double checked the Coordinate system. Somehow the
>> points are there, and when you go to a specific point, it takes you to
>> the right place, but the point just isn't appearing on the map.
>> Has anyone else encountered a problem similar to this? I searched a bit
>> through the bug tracker, but found nothing. Im also planning on moving
>> all our data over to a PostGIS database and hopefully this might fix the
>> problem, but until then I would really rather use 2.0 instead of 1.8.
>> Thanks.
>Message: 2
>Date: Tue, 19 Nov 2013 21:59:23 +0000 (GMT)
>From: Michael White <crwban681 at yahoo.co.uk>
>To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
>Subject: [Qgis-user] How can I use a jpg of map as base layer & then
>Message-ID:
>    <1384898363.28566.YahooMailNeo at web172102.mail.ir2.yahoo.com>
>Content-Type: text/plain; charset="iso-8859-1"
>Hello everyone. The latest map for my atoll was 1986 (paper only 1:25,000), but I have a high res jpg which I've uploaded into QGIS 2.0 OK. Map was in UTM zone 4. I have also successfully uploaded a GPX file of waypoints that I'd like to display on the map. At the moment I can still move the jpg around in the map window. What do I need to do to fix the map in place and how can I relate the waypoints (WGS84) to the map. Is there a way to select a lat/long on the map and then the same waypoint in my GPX file, thus linki9ng the two things? Thanks Michael
>Dr Michael White
>Marine Zoologist
>Tongareva Atoll
>-------------- next part --------------
>An HTML attachment was scrubbed...
>URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131119/09d55008/attachment-0001.html>
>Message: 3
>Date: Tue, 19 Nov 2013 14:06:15 -0800
>From: Alex Mandel <tech_dev at wildintellect.com>
>To: Michael White <crwban681 at yahoo.co.uk>,
>Subject: Re: [Qgis-user] How can I use a jpg of map as base layer &
>Message-ID: <528BE0D7.3060806 at wildintellect.com>
>Content-Type: text/plain; charset=ISO-8859-1
>> Dr Michael White
>You're slightly confused. The map will always be pan enabled, you aren't
>actually moving the image, you're changing the center point of your
>view. What you want to do is enable projection on the fly, making sure
>that the projection definition for your jpg is correct to begin with.
>Once you do that your GPX points will overlay properly.
>http://www.qgis.org/en/docs/user_manual/working_with_projections/working_with_projections.html
>Thanks,
>Alex
>Message: 4
>Date: Tue, 19 Nov 2013 18:03:08 -0500
>From: Carlos Cerd?n <sig.upagu at gmail.com>
>Message-ID: <528BEE2C.601 at gmail.com>
>Content-Type: text/plain; charset=ISO-8859-1; format=flowed
>If I'm not confused too, you must georeference your image. Two
>sample-google results:
>http://glaikit.org/2011/03/27/image-georeferencing-with-qgis/
>http://www.digital-geography.com/qgis-tutorial-i-how-to-georeference-a-map/
>Carlos
>El 19/11/13 17:06, Alex Mandel escribi?:
>>> Dr Michael White
>> Thanks,
>> Alex
>Message: 5
>Date: Tue, 19 Nov 2013 15:25:45 -0900
>From: Daniel Kranich <daniel at nusalaska.com>
>Message-ID: <528C0189.20805 at nusalaska.com>
>Content-Type: text/plain; charset=UTF-8; format=flowed
>oops... I don't use mailing lists often so Its not surprising.
>I know that "Rangeview" does not have any attributes and the ID's are
>null, but it was simply meant to be used for visual purposes on the map
>and not meant to have any data associated with it.
>I will go ahead and file a bug report. In the mean time I guess I'm
>stuck with 1.8 :(
>Daniel
>On 11/19/2013 1:16 PM, Andreas Neumann wrote:
>> Hi Daniel,
>> It seems you answered only me personal and forgot to post this
>> information to the list.
>> I can confirm the strange behaviour on both QGIS 2.0 and QGIS master.
>> You should open a bug report.
>> I can open both files in FME, but "Rangeview" does not contain any
>> attributes and all the ids are NULL values.
>> Andreas
>> Am 19.11.2013 21:56, schrieb Daniel Kranich:
>>> Well I have done a lot more troubleshooting. here is what I found:
>>> -It seems that it is only this particular shapefile.
>>> -I can see the points if I am zoomed out far enough, but as I zoom in,
>>> they disappear.
>>> -When zoomed out far enough to see them, I am unable to select them
>>> using the rectangle select tool
>>> -This is the case even if I load it into a new project.
>>> -If I select a specific point in the attribute table and hit the "zoom
>>> to selected rows" button, it seems to take me to the correct place,
>>> however the points don't appear.
>>> -There are a few points that actually DO appear.
>>> -ALL the points appear at ALL zoom levels in 1.8
>>> -I have tried messing with the "Scale Dependent Rendering" and that
>>> changes nothing.
>>> Here are some screenshots:
>>> The points on the far upper right are the ones I would like to
>>> see/manipulate: http://prntscr.com/25apve
>>> After zooming in: http://prntscr.com/25aqic
>>> Here is a link to download two shape files. "Water Nodes" is the one
>>> that is a problem. the "Rangeview" shape file is there as reference for
>>> the general area where some of the Water Nodes should be appearing. Both
>>> are set to EPSG:26934 - NAD83 / Alaska zone 4 coordinate system:
>>> http://www.mediafire.com/download/l8nhd1xzmg3v6z2/WaterNodes.zip
>>> Thanks for the help
>>> On 11/19/2013 11:23 AM, Andreas Neumann wrote:
>>>> Hi Daniel,
>>>> shows the problem?
>>>> Andreas
>>>>> Hello,
>>>>> the map.
>>>>> Thanks.
>Message: 6
>Date: Tue, 19 Nov 2013 15:51:29 -0900
>Message-ID: <528C0791.10802 at nusalaska.com>
>Well It looks like I solved my own problem. I went in and found that
>there was a point with NULL in all the attribute fields, so I deleted
>that point and saved the file and everything shows up now.
>Weird.
>Daniel.
>> map and not meant to have any data associated with it.
>> stuck with 1.8 :(
>> Daniel
>>> Hi Daniel,
>>> Andreas
>>>> they disappear.
>>>> changes nothing.
>>>> Both
>>>> Thanks for the help
>>>>> Hi Daniel,
>>>>> shows the problem?
>>>>> Andreas
>>>>>> Hello,
>>>>>> upgraded
>>>>>> files.
>>>>>> symbols
>>>>>> data,
>>>>>> the map.
>>>>>> points
>>>>>> top of
>>>>>> Somehow the
>>>>>> you to
>>>>>> a bit
>>>>>> moving
>>>>>> fix the
>>>>>> Thanks.
>Message: 7
>Date: Wed, 20 Nov 2013 09:31:17 +0100
>From: Radim Blazek <radim.blazek at gmail.com>
>To: qgis-developer <qgis-developer at lists.osgeo.org>
>Cc: QGIS Users <qgis-user at lists.osgeo.org>,    Michael Spencer
>    <spencer.mike.r at gmail.com>
>Subject: [Qgis-user] Cannot create issue (was: raster artefact in
>    composer    pdf export)
>Message-ID:
>    <CAEMrtYr4-msGwuZr82Te0SbfHsTN1uZoPhzT9pVXuSY4e5541w at mail.gmail.com>
>See below the difficulties to create a new issue. Can somebody comment?
>Radim
>On Tue, Nov 19, 2013 at 3:13 PM, Michael Spencer
><spencer.mike.r at gmail.com> wrote:
>> Hi I've been trying to report an issue/bug, as requested. The registration
>> process is a very long way from straight forward.
>> I found this page with instructions (no links from qgis home pages, found
>> via a search): http://hub.qgis.org/wiki/quantum-gis/Bugreports. The option
>> for creating an OSGeo account doesn't seem to work (the link works but the
>> process fails, with no explanation why).
>> I've tried to create an account via https://www.osgeo.org/user but the only
>> options are to login or request a new password, not register a new user.
>> I've set up a OSGeo wiki account, but this doesn't work either.
>> Can somebody point me in the right direction as life is too short for this
>> much faff!
>> Ta,
>> Michael
>> On 15 November 2013 10:48, Radim Blazek <radim.blazek at gmail.com> wrote:
>>> I am able to reproduce it with reprojected raster, the dashed lines
>>> appear on original raster extent border. Until we fix that, the only
>>> solution I see is to save reprojected raster and use not reprojected
>>> raster in composition.
>>> Please create the issue anyway.
>>> Radim
>>> On Fri, Nov 15, 2013 at 11:29 AM, Radim Blazek <radim.blazek at gmail.com>
>>> wrote:
>>> > On Thu, Nov 14, 2013 at 6:33 PM, Michael Spencer
>>> >> Hi all,
>>> >> Just updating a figure I originally produced in v1.8 without problem.
>>> >> The
>>> >> aerial photo now generates a dashed line (top and bottom) artefact when
>>> >> I
>>> >> export to pdf.
>>> >> Example here: http://ubuntuone.com/5OmDksQ5O8ppjAX4172ctl
>>> > Please create a new issue and attach a small raster + project with
>>> > comosition reproducing the problem.
>>> > The raster is reprojected?
>>> > The raster is using resampling?
>>> > Radim
>>> >> Any ideas how to fix it?
>>> >> Ta,
>>> >> Michael
>>> >> ps copyright to appear in figure caption ;)
>Message: 8
>Date: Wed, 20 Nov 2013 09:36:18 +0100 (CET)
>From: Stefano Masera <stefano.masera at arpa.piemonte.it>
>To: tech at wildintellect.com
>Cc: qgis-user <qgis-user at lists.osgeo.org>
>Subject: Re: [Qgis-user] install qgis 2 in ubuntu 13.10
>Message-ID:
>    <365511175.7025068.1384936578128.JavaMail.root at zstore.arpa.piemonte.it>
>Content-Type: text/plain; charset="utf-8"
>Thank you very much to all,
>now I'm ok.
>My error was to install qgis with the command: apt-get install qgis python-qgis, b efore adding repository.
>This install qgis 1.7.
>After "apt-get --purge remove" all the qgis 1.7 packages and adding the repository http://qgis.org/debian saucy main all it's ok.
>Thank you again!
>Stefano
>----- Messaggio originale -----
>Da: "Alex Mandel" <tech_dev at wildintellect.com>
>A: "Lee Hachadoorian" <Lee.Hachadoorian+L at gmail.com>, "Stefano Masera" <stefano.masera at arpa.piemonte.it>
>Cc: "qgis-user" <qgis-user at lists.osgeo.org>
>Inviato: Marted?, 19 novembre 2013 19:43:01
>Oggetto: Re: [Qgis-user] install qgis 2 in ubuntu 13.10
>On 11/19/2013 06:07 AM, Lee Hachadoorian wrote:
>> On 11/19/2013 04:12 AM, Stefano Masera wrote:
>>> Hi list?
>>> Is it possible to install qgis 2 in ubuntu 13.10?
>>> From the official repository
>>> (http://www.qgis.org/en/site/forusers/alldownloads.html#ubuntu) I can only
>>> install qgis 1.7.
>>> Thanks
>>> Stefano
>> Stefano,
>> I would strongly recommend using ubuntugis-unstable, which, in spite of its
>> name, is quite stable. You will get up to date versions of other useful
>> dependencies, particularly GDAL.
>> sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
>> sudo apt-get update
>> sudo apt-get install qgis python-qgis qgis-plugin-grass
>> Best,
>> --Lee
>FYI, we don't have packages for Saucy yet in ubuntu-gis. So you'll have
>to use the qgis.org repo for now. I don't know the ETA as I'm not sure
>who plans to do upload the new builds, it's currently being discussed on
>the ubuntugis mailing list.
>Thanks,
>Alex
>URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131120/5bd68586/attachment-0001.html>
>Message: 9
>Date: Wed, 20 Nov 2013 08:47:55 +0000
>From: Jos? Pedro Santos <zpsantos1 at hotmail.com>
>To: "tech at wildintellect.com" <tech at wildintellect.com>, Lee
>    Hachadoorian    <lee.hachadoorian+l at gmail.com>, Stefano Masera
>Cc: QGIS Mailing List <qgis-user at lists.osgeo.org>
>Message-ID: <DUB110-W19AFCD72ED4CD4D8D650B7E0E60 at phx.gbl>
>Hey,
>Another alternative is to install from Synaptic Package.
>Regards,
>Jos? Santos
>> Date: Tue, 19 Nov 2013 10:43:01 -0800
>> From: tech_dev at wildintellect.com
>> To: Lee.Hachadoorian+L at gmail.com; stefano.masera at arpa.piemonte.it
>> CC: qgis-user at lists.osgeo.org
>> >> Hi list?
>> >> install qgis 1.7.
>> >> Thanks
>> >> Stefano
>> > Stefano,
>> > sudo apt-get update
>> > Best,
>> > --Lee
>> Thanks,
>> Alex
>URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131120/c8af600a/attachment-0001.html>
>Message: 10
>Date: Wed, 20 Nov 2013 08:54:13 +0000
>To: Chuck Young <wylie1066 at gmail.com>, QGIS Mailing List
>Subject: Re: [Qgis-user] Google earth KLM files
>Message-ID: <DUB110-W179E7CE53751868800051FE0E60 at phx.gbl>
>Hey,
>What about using OSM? Is a better choise.
>Good Luck.
>Regards,
>Jos? Santos
>Date: Mon, 18 Nov 2013 15:34:52 -0400
>From: wylie1066 at gmail.com
>To: Qgis-user at lists.osgeo.org
>Subject: [Qgis-user] Google earth KLM files
>I know some of you have talked about how to get and use the Google Earth KLM (?) files for background images.  I need to get a set for an area in the Dominican Republic.  I was using the Google satelite imagry and it was nice but It is loading sporatically because I am using Qgis 2.0, and because I have a slow connection I thought if I had the files locally it would not have so much Internet traffic and my bandwidth wouldn't kill me.
>Any help and info would be very much appreciated.
>Chuck
>URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131120/dea0a4dd/attachment-0001.html>
>Message: 11
>Date: Wed, 20 Nov 2013 01:34:00 -0800 (PST)
>From: magerlin <MAP at ramboll.dk>
>Subject: [Qgis-user] Qgis working or dead?
>Message-ID: <1384940040993-5090083.post at n6.nabble.com>
>Content-Type: text/plain; charset=us-ascii
>Hi
>Many processes in (Q)gis can take a long time when working with large files.
>On my Windows 7 PC such processes (like doing a spatial join) usually ends
>up in a dimmed screen and the text (Not responding) in the window bar:
><http://osgeo-org.1560.x6.nabble.com/file/n5090083/Qgis_not_responding_or_working.png>
>Problem is that it sometimes means Qgis is dead and at other times just that
>Qgis is working hard.
>Is there any way to see what is the situation? (the bar showing percentage
>is also frozen, so that is not a solution)
>Could Qgis perhaps have some general status field showing wether it is dead
>or alive?
>Regards Morten
>Qgis 1.8.0 Stand alone installer and/or
>Qgis 2.0.1 OSGeo and/or
>Qgis 2.1.0-Master    weekly 64bit (5f5cd4c)
>Windows 7, 64bit
>View this message in context: http://osgeo-org.1560.x6.nabble.com/Qgis-working-or-dead-tp5090083.html
>Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>Message: 12
>Date: Wed, 20 Nov 2013 11:07:46 +0100
>From: Richard Duivenvoorde <rdmailings at duif.net>
>To: Radim Blazek <radim.blazek at gmail.com>,    qgis-developer
>Subject: Re: [Qgis-user] Cannot create issue (was: raster artefact in
>Message-ID: <528C89F2.8070903 at duif.net>
>There is a (very concise) text here:
>http://www.qgis.org/en/site/forusers/support.html#issue-tracker
>which is working for me :-(
>After creating an Osgeo account (of which I'm pretty sure Mike already
>has (if he is the mike I know :-) ), you can 'just login' at qgis with
>your osgeo account (which if you have not 'registred' yet with QGIS will
>add you to our 'shadow list of users', giving us the opportunity to add
>some user related info/permissions).
>So the right track would be
>1) create a new osgeo user if not already done:
>https://www2.osgeo.org/cgi-bin/ldap_create_user.py
>2) use THAT username/password to login at QGIS
>via (http://hub.qgis.org/projects/quantum-gis/issues)
>https://hub.qgis.org/login
>if this is NOT working, please let me know what your (osgeo/qgis) userid
>is, I can look it up in our user list.
>And if the text is not clear enough, please take some time to make it
>clear (an email to me or community list is ok). As
>http://www.qgis.org/en/site/forusers/support.html#issue-tracker should
>be clear and working.
>Regards,
>> Radim
>>> much faff!
>>> Ta,
>>> Michael
>>>> Radim
>>>>>> Hi all,
>>>>>> The
>>>>>> I
>>>>>> export to pdf.
>>>>> Radim
>>>>>> Ta,
>>>>>> Michael
>End of Qgis-user Digest, Vol 93, Issue 42
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131121/910b47db/attachment.html>
