[Qgis-user] Contours lines interpolation
    Alexandre Neto
    senhor.neto at gmail.com
    Fri Nov 22 02:58:49 PST 2013
Hello Alfonso,
you can interpolate your lines to a raster, and then create the 1 m contour
lines from it.
Be aware that this is an interpolation process and the precision of the
resulting lines are naturally equal or even lower than the original ones.
hope it helped.
Alexandre Neto
No dia 21 de Nov de 2013 18:20, "Alfonso Flaquer" <alfonsofla220 at gmail.com>
escreveu:
> Dear list
> it´is possible to create a shape with contour lines each 1 m from a shape
> with contours lines each 10 m?. I assume theare is a simple way to do this
> in qgis,  just can´t find it.
> Regards,
> Es posible crear un shape con curvas de nivel cada 1 m partiendo de un
> shape con curvas de nivel cada 10 m?. Asumo que hay una forma simple de
> hacerlo, pero no puedo encontrarla.
> Gracias.
> AfLa
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131122/20f7b27b/attachment.html>
