[Qgis-user] qgis-server issue whit custom RS. Impossible to work with planetary data (sorry for possible cross-posting)
andrea pacifici
pacifici at irsps.unich.it
Mon Nov 25 12:42:28 PST 2013
Hi there,
I'm trying to set-up a WMS server using the qgis-server (qgis 2.0 and
Ubuntu 12.04) and data of planet Mars. Since Mars is not the Earth I
must use custom RS. So, I have realized a qgis project with Martian
data and I have properly filled fields in "OWS server" of "Project
Properties".
Then I started a new Qgis project using the same custom RS and I try
to add the layers using "Add layer from a server" command. Once Qgis
is connected to the server the layers name are visible but layers
don't appears.
WMS Log Messages report:
Map request error (Title:Service Exception; Error:Request contains a
CRS not offered by the server for one or more of the Layers in the
request.
The WMS vendor also reported: Could not create output CRS; URL:
http://localhost/cgi-bin/liz_test/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=-112389.97944659927452449,-163304.16266460958286189,99132.64792997627228033,-33665.77575473205070011&CRS=USER:100000&WIDTH=574&HEIGHT=352&LAYERS=mola&STYLES=&FORMAT=image/jpeg&DPI=96&MAP_RESOLUTION=96&FORMAT_OPTIONS=dpi:96
I copied my own CRS in the RS database of Qgis in
/usr/share/qgis/resources/srs.
db but I have still the same issue.
Any idea?
Thanks!
Andrea
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131125/882b8bfd/attachment.html>
