[Qgis-user] strange results when calculating area and perimeter
rob vech
rob.vech87 at gmail.com
Tue Nov 26 01:26:37 PST 2013
Hello,
I'm using the wounderful (:)) qgis Dufour 2.0.1 and I'm trying to
calculate area and perimeter from a simple shapefile with CRS WGS84UTM32
following these steps:
1) set up the CRS of the project to WGS84UTM32 (on the fly
transformation is checked)
2) load the shapefile
3) click on it with the identifier tool (identify features) I obtain:
- area: 19.321 km²
- perimeter: 0.221 m (!!!!)
4) then I try to calculate in the table ...
- area: 2,301,030,218 while in the preview was 19,320,205.394043 (!!!!)
- perimeter: 2,859,402,286 while in the preview was 20,391.7709396732 (!!!!)
then I modify the general CRS settings for new project (settings -->
options) to WGS84UTM32 and, after reloading qgis, I did steps 1, 2 again
and I obtained:
3bis) in the identify tool:
- area: 19.321 km²
- perimeter: 20.392 km
4bis) and in table:
- area: 19,320,205.3
- perimeter: 20,391.771
The second way seems to give more consistent results.
But why should I setup the general CRS option if I've already setup the
project CRS?
Shouldn't the geometry function all referred to the project settings?
There is something of wrong in my first procedure?
Thank you in advance
rob
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131126/502954fc/attachment.html>
