[Qgis-user] Counting the sum of points in a polygon
Carlos López PSIG carlos.lopez at psig.es
Wed Nov 27 05:02:43 PST 2013
Hi Steven,
You try to create a point layer from polygon, from polygon's vertexs
you can use SAGA (procesing plugin) "Convert poligon/line vertices to point"
And then you work with the atribute table the point layer
Luck,
* <http://www.psig.es> *
*Carlos López Quintanilla*
www.psig.es
+34 699.680.261
2013/11/27 Andreas Neumann <a.neumann at carto.net>
> Hi Steven,
> There is the zonal stats plugin which can do something similar. Have you
> tried that?
> Andreas
> Am 27.11.2013 12:13, schrieb Steven Campbell:
> > Hi all
> > Can anyone tell me how it is possible to count up the total number of
> points, or sum up a value against each point within a boundary?
> > For example I have seven points, in a polygon, each point has an
> attribute of differing numbers and I want to assign the sum value of this
> attribute against the polygon.
> > I can't see anything instantly within the formula box that can help me
> do this.. or I might just be completely overlooking it!
> > Thanks
> > Steve
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131127/1761b119/attachment.html>
