[Qgis-user] GeoPDF / Map2PDF
Andre Joost
andre+joost at nurfuerspam.de
Fri Nov 29 07:15:12 PST 2013
Am 28.11.2013 23:03, schrieb Alex Mandel:
> On 11/28/2013 01:43 PM, Chuck Young wrote:
>> Is there a way to directly use the data in a GeoPDF created by Map2PDF in
>> Qgis? Or maybe a plugin that will read it ????
>> Thanks!
>> Chuck
> Yes, it does exist in gdal
> http://www.gdal.org/frmt_pdf.html
> http://www.gdal.org/ogr/drv_pdf.html
> However you may not have a version of gdal built with it.
> You probably need gdal> 1.10
That should be incorporated in QGIS 2.0.1.
Settings -> Options, GDAL tab
Or is Geospatial PDF something different than GeoPDF?
Greetings,
André Joost
