[Qgis-user] osgeo4w 64 bit and updatings
Andrea Peri
aperi2007 at gmail.com
Fri Oct 4 00:11:08 PDT 2013
Hi Andreas, Paolo
thx for clarification.
Andrea.
2013/10/4 Andreas Neumann <a.neumann at carto.net>
> Hi Andrea,
> Both 32bit and 64bit versions are updated every night (unless there are
> technical troubles).
> I expect that for the long run there will only be a 64bit version. So I
> would definitely go with the 64bit version if you have a Win64 machine.
> For a couple years we will have two versions in parallel, but 64bit is
> definitely the way to go from now on.
> You can install both versions in parallel if you make sure that the
> installation directory, the directory for the icons in the start menu
> and the local package repository are in separate places
> I don't see much reason to use the 32bit version though. It is in no way
> better than the 64 bit version.
> Andreas
> Am 04.10.2013 06:39, schrieb Andrea Peri:
> > Hi,
> > I install the qgis 64 bit from the osgeo4w 64bit.
> > It work pretty smart.
> > But I like to know if it is daily updated as it son osgeo4w-32bit.
> > Or to have the more updated qgis-dev is better stay on the 32 bit
> version.
> > Also I like to know if is possible maintain on the same window machine a
> > qgis-dev from osgeo4w-32bit and a qgis-dev from osgeo4w-64 bit.
> > avoiding any trouble between them.
> > Thx,
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131004/3b6f9504/attachment.html>
