[Qgis-user] [OSGeo-UK] Spurious Cryllic Script
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Fri Oct 4 08:29:52 PDT 2013
Thanks. I see now why it says UK (which as James surmised is likely
Ukrainian).
My list looks like this - hence my confusion:
[image: Inline images 1]
I wonder why they're different given we're both using 2.0.1. - Mine is from
the installer. Are you using the OSGEO version? Might it be that?
Seems like it may be a bug - I guess they're supposed to be the same.
Jonathan
On 4 October 2013 16:18, JOHN WEBBER <john.m.webber at btinternet.com> wrote:
> Jonathan,
> Attached as requested. I do remember when I originally downloaded Qgis
> that I wondered about the "UK" setting but as everything appeared in
> English I was not bothered by it. I see now that there is no specific "GB"
> setting just the combined US and GB flag.
> Screenshot attached.
> John
> *From:* Jonathan Moules <jonathanmoules at warwickshire.gov.uk>
> *To:* "Passmore, James H." <jpass at bgs.ac.uk>
> *Cc:* JOHN WEBBER <john.m.webber at btinternet.com>; "uk at lists.osgeo.org" <
> uk at lists.osgeo.org>
> *Sent:* Friday, 4 October 2013, 16:01
> *Subject:* Re: [OSGeo-UK] Spurious Cryllic Script
> Interesting notion. For me at least Ukrainian appears as "Українська" no
> matter the language I change it to - I would never have guessed it was
> Ukrainian, but looked up the flag on wikipedia.
> "uk" is the ISO 639-1 value for Ukrainian, but that would suggest his
> system settings were set to Ukrainian or QGIS was picking them up as such.
> John - can you share a small screenshot of your locale" screen and the
> language list?
> Jonathan
> On 4 October 2013 15:37, Passmore, James H. <jpass at bgs.ac.uk> wrote:
> "UK" I think may stand for Ukraine as far as location is concerned, you
> may want to use "GB" instead
> James Passmore
> GIS and WWW Specialist
> Geoscience Products and Services,
> British Geological Survey,
> http://www.bgs.ac.uk/
> +44 (0)115 936 3125
> @nmtoken
> > -----Original Message-----
> > From: uk-bounces at lists.osgeo.org [mailto:uk-bounces at lists.osgeo.org] On
> > Behalf Of JOHN WEBBER
> > Sent: Friday, October 04, 2013 2:16 PM
> > To: Jonathan Moules
> > Cc: uk at lists.osgeo.org
> > Subject: Re: [OSGeo-UK] Spurious Cryllic Script
> > Hi Jonathan,
> > Thanks for your suggestion, it produced a solution. Under Settings -
> > Options - Locale I had to change "UK" to US English and restart. Why
> > "UK" produced this effect is beyond my understanding.
> > Thanks again
> This message (and any attachments) is for the recipient only. NERC is
> subject to the Freedom of Information Act 2000 and the contents of this
> email and any reply you make may be disclosed by NERC unless it is exempt
> from release under the Act. Any material supplied to NERC may be stored in
> an electronic records management system.
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131004/0dbb79a0/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131004/0dbb79a0/attachment.png>
