[Qgis-user] Dufour OSM import: success but no layer
Joe Lertola joe at joelertola.com
Mon Oct 7 20:01:04 PDT 2013
I am also having trouble figuring out how to load OpenStreetMap data. I have not found the documentation for this feature. I first chose Vector/OpenStreetMap/Download Data and I got a file with a .osm extension. I then chose Vector/OpenStreetMap/Import Topology form XML. A window opened where I could choose my downloaded data and save a new file with a .db extension. I then chose Vector/OpenStreetMap/Export topology to SpatiaLite. I got a window that lets you set the export type and a layer name. Clicking ok seems to process but nothing shows up on the map. Do I need to check the items available in the window after pressing the Load from DB button?
I just tried clicking the button a second time and I get an error message saying that the layer already exists. Then the layer does show up.  Perhaps this is a bug.
-Joe
On Oct 7, 2013, at 12:27 AM, Andre Joost wrote:
> Am 06.10.2013 12:17, schrieb Cascafico Giovanni:
>> I attempted
>> vector>  Openstreetmap>  import
>> dialog informed me of a successful operation, but where are the 3 layers?
>> Map pane permanently empty :(
> Have you performed the last step vector ->Openstreetmap -> Export to spatialite?
> That's where the layers are created.
> HTH,
> André Joost
> Qgis-user mailing list
