[Qgis-user] Scalebar reference point usage in Atlas Generation
Andreas Neumann
a.neumann at carto.net
Tue Oct 8 11:43:54 PDT 2013
Hi Alexandre,
This is already possible in QGIS 2.0 - there you can specify the
"Alignment" in the "Display" group.
Are you using 1.8? I don't remember if this option was already was
present in 1.8.
Hope this helps.
Andreas
Am 08.10.2013 15:57, schrieb Alexandre Neto:
> While using Atlas generation, I'm producing maps with several diferent
> scales, and therefore diferent scalebars.
> Having the scalebar at the right hand side of the page, whenever my scale
> change, either the scale does not align well with the map frame or just
> gets out of the page.
> Is there a way to prevent this? I was hoping that setting the Reference
> point to the right hand side would work, but it doesn't.
> Best regards,
> Alexandre Neto
> Qgis-user mailing list
