[Qgis-user] New QGIS 2 with grass-plugin (from ubuntugis-ppa) on Ubuntu
Carlos Cerdán
sig.upagu at gmail.com
Wed Oct 9 05:54:14 PDT 2013
Hi Johannes:
Probably is something about detecting dependencies, I don know, I'd had
this issue, but it was solved uninstalling all related packages and then
installing (first) dependencies that are not detected and finally packages
that don't detect them.
Good luck
Carlos
2013/10/9 Johannes Radinger <johannesradinger at gmail.com>
> Hi,
> I followed the instructions to install QGIS on my Ubuntu (Precise) machine.
> As I also depend on GRASS GIS I wanted to install also the QGIS-GRASS
> plugin.
> On my computer I have grass64 (6.4.3), grass65 and grass70. I just want to
> use QGIS in combination with the stable grass64. I installed qgis via the
> ubuntugis-ppa:
> sudo apt-get install python-software-properties
> sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
> sudo apt-get update
> sudo apt-get install qgis python-qgis qgis-plugin-grass
> but when I try to install the grass-plugin I get following error:
> The following packages have unmet dependencies:
> qgis-plugin-grass : Depends: qgis-plugin-grass-common (=
> 2.0.1-1~precise1) but 2.0.1-2+precise1 is to be installed
> So what causes the problem and how can I solve it?
> /Johannes
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131009/caa0afa1/attachment.html>
