[Qgis-user] Display label only selected features in QGIS 2.0
Larry Shaffer
larrys at dakotacarto.com
Mon Oct 14 13:45:21 PDT 2013
On Mon, Oct 14, 2013 at 12:01 AM, chingchai humhong
<chingchai.h at gmail.com>wrote:
> Hi QGIS User
> How to display label only selected features in QGIS 2.0
There is no current function of choosing to show labels (in a temporal
fashion) for the current selection. However, there are new tools in QGIS
2.0 to help show only the labels you want. Depending upon your desired
workflow, consider using 'Show Label' data defined option (under Vector
Layer Properties Dialog -> Labels -> Rendering section). You can map an
attribute field for your layer, or define an expression.
[Show Label data definition description]
Expected input: bool [1=True|0=False]
Valid input types: string, int, double
If not using an expression, but instead mapping an attribute field, you can
then either edit the attribute table accordingly (e.g. create a selection
and update existing field values using the Attribute Table Editor), use the
Show/Hide Label tool, or toggle the check box in the Change Label
Properties dialog.
Manipulating the attribute table allows for different expressions to be
applied, while the Show/Hide Label allows you to interactively work with
the labels on the map canvas:
[Show/Hide Labels tool tip]
Click or marquee on feature to show label
Shift+click or marquee on label to hide it
Acts on currently active editable layer
Regards,
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
> thank you
> Chingchai Humhong (chingchai by famous)
> Regional Center of Geo-Informatics and
> Space Technology, Lower Northern Region
> Naresuan University Phitsanulok 65000
> Mobile: 08-4624-6278
> Blog: http://nu-gis.blogspot.com
> Website: http://www.map.nu.ac.th <http://map.nu.ac.th/>
> Website: http://www.cgistln.nu.ac.th <http://www.cgistln.nu.ac.th/web/>
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131014/cb41b336/attachment.html>
