[Qgis-user] PostGIS layer query issue
Allar Haav allar.haav at gmail.com
Tue Oct 15 03:12:58 PDT 2013
Hi all,
I am experiencing a weird nuisance with PostGIS layers. Namely, the
primary key of the table is of integer type. However, when selecting
features via expression or setting rule-specific styles using this ID
field, it seems that the integers are not treated as properly numeric.
For example, a query of "id" >= 2 shows all features with ID starting
with 2 or bigger number. It does not find features with ID of 10000 for
example. Therefore I have to use toint("id") >= 2, but I have a strange
feeling that this workaround is not really a solution. Oddly enough, an
SQL query with DB Manager plugin works fine. To make things even more
weird, the layer "Filter" feature also seems to function properly.
I'm using QGIS 2.0.1 from OSGeo4W on Win 7 64-bit.
Any ideas?
Regards,
Allar
