[Qgis-user] SPIT crashes in QGIS 2.1 & 2.0
Víctor Manuel Herreros Villanueva
vherreros at ucm.es
Tue Oct 15 03:51:09 PDT 2013
Hello all,
I've been trying QGIS Dufour and I've realized about a problem in Ubuntu
versions of QGIS 2 (Windows versions don't suffer this problem).
When trying to import local shape files into PostGIS database through SPIT
plugin, if you select more than two shape files then QGIS silently closes.
If you select just one or two files then the import process runs smoothly.
The problem is not due to badly-formed shape files, cause I'm able to
import all of them one by one, and then use them in a QGIS project.
This is the environment I'm using:
- Operating System and version: Ubuntu 12.04.3 LTS precise on 64bit
Oracle Virtualbox virtual machine platform.
- QGIS version: 2.1.0-Master (though I got the same behaviour on stable
QGIS 2.0.1).
- PostGIS version: PostgreSQL 9.3.0.1 plus PostGIS 2.1.0-2.
- QGIS installed by apt-get from http://qgis.org/debian-nightly.
- At what time did it break: When trying to import more than two shape
files into PostGIS through SPIT plugin. It doesn't matter wether you have
an open project or you've just started your QGIS sessions with a blank new
project.
- What exactly is the error: QGIS closes without further notification.
It leaves a crash file in /var/crash/, whose apport-retrace output can be
get on this link:
http://www.mediafire.com/view/8n8e8qjrbulx0m1/_usr_bin_qgis.bin.1000.crash_retrace
Has anybody experienced sucha failure or found any solution?
Thanks in advance.
<http://www.ucm.es/> *Universidad Complutense de Madrid*<http://www.ucm.es/>
*Víctor Manuel Herreros Villanueva*, PhD.
Project Manager *Facilities Management
Data Warehouse*
Jardín Botánico
Av. Complutense s/n
28040 Madrid
Spain *Phn. no. (+34) 91 394 7275
Fax no. (+34) 91 394 4773* vherreros at ucm.es
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131015/eae1a66e/attachment.html>
