[Qgis-user] Saving layers
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Thu Oct 17 06:36:01 PDT 2013
Hi List,
  I'm wondering if QGIS can save links to layers as stand alone files,
similar to how ArcMap does it.
I know I can save the style, but I want to save everything about the layer
including data location etc in a file which I can then share with others.
The style only saves the style.
I can't seem to find such a function - is there one?
Thanks,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131017/cc8d9285/attachment.html>
