[Qgis-user] Saving layers
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Thu Oct 17 11:29:08 PDT 2013
Jonathan -
Sorry for the noise in my previous posting. I didn't see the post
explaining it was a Oracle based layer. I don't use Oracle, but the
following works for postgres in QGIS 2.0:
* Style the layer
* Push the Layer properties -> Style -> Save Style button. It will
show a drop-down list with 3 choices: "QGIS Layer style file", "SLD
file", "Save style in database (Postgres)". Choose "Save style in
I don't know if the "Save style in database..." option exists for
Oracle. It doesn't exist for MS-SQLServer. Make a feature request if it
doesn't. It can't be a major exercise to convert the postgres specific
code to oracle specific code for this function.
As a last resort you can make a "standard" project file. When the users
want add a Oracle layer they can use this project file from the "Layer"
-> "Embed layers and groups", choose the project file you created, and
choose the oracle layer from this "standard" project to embed into their
own project.
Regards
Bo Victor Thomsen
Aestas-GIS
Denmark
Den 17-10-2013 18:55, Jonathan Moules skrev:
> Hi Richard,
> That's useful to know, however I was planning on using it with Oracle
> layers so it wouldn't work for me. Basically what we do with ArcMap
> (.lyr) and MapInfo (.tab) is create links to data which we share on a
> network drive so that our users can easily access our data pre-styled.
> It works quite well so if we go toward QGIS we'd want to use it there too.
> Cheers,
> Jonathan
> On 17 October 2013 17:47, Richard Duivenvoorde <rdmailings at duif.net
> <mailto:rdmailings at duif.net>> wrote:
> On 17-10-13 15:36, Jonathan Moules wrote:
> > Hi List,
> > I'm wondering if QGIS can save links to layers as stand alone
> files,
> > similar to how ArcMap does it.
> > I know I can save the style, but I want to save everything about the
> > layer including data location etc in a file which I can then
> share with
> > others. The style only saves the style.
> > I can't seem to find such a function - is there one?
> Hi Jonathan,
> one 'hidden' feature is that if you save a style as a qml file next to
> your data (shape file), and name it exactly the same as your shape,
> loading the shp in qgis will load the style with it.
> BUT: only working with filebased data, and NOT saving your extent
> I think.
> You can save a project, and use it as a template. And if I recall
> correct there was some way to use one project as a subprobject for
> another one, but I cannot find it anymore...
> Regards,
> Richard
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use
> it, or disclose it to anyone else. If you have received this
> transmission in error please notify the sender immediately. All email
> traffic sent to or from us, including without limitation all GCSX
> traffic, may be subject to recording and/or monitoring in accordance
> with relevant legislation.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131017/3a8af56b/attachment.html>
