[Qgis-user] Customising QGIS DuFour install - Windows
Lene Fischer
lfi at life.ku.dk
Thu Oct 17 23:53:44 PDT 2013
Hi Johanna
I´m not on the dev-list, so my answer is from a user point of view.
You can save the Printcomposer as a template and there choose the legend font, label font, scalebarfont as you choose.
ANd the save it as a template.
It would be smart if it was possible to change the font in a 'composer setting'
I know this is not optimal - but make this as a new featurerequest on the 'bug'-list.
Regards
Lene Fischer
________________________________________
Fra: qgis-user-bounces at lists.osgeo.org [qgis-user-bounces at lists.osgeo.org] på vegne af Johanna.Botman at griffith.nsw.gov.au [Johanna.Botman at griffith.nsw.gov.au]
Sendt: 18. oktober 2013 01:42
Til: Jonathan Moules
Cc: qgis-user at lists.osgeo.org
Emne: Re: [Qgis-user] Customising QGIS DuFour install - Windows
Thanks for the answer Jonathan, but I don't believe this answers my
question.
If I change the font setting under Settings | Options | General, it also
changes ALL the fonts for the GUI. I only want to be able to change the
default font for the composer for a particular project.
I have been told that I can edit the project file in a text editor and
change all font instances to the font that I want. But I'm not happy with
that solution either because it would mean completing the project and then
changing everything. I would prefer to be able to see what my layout looks
like as I am creating it. Font size and font weight play a big part in the
look and feel of a map. If I changed the font in the project file, I'd
probably have to revisit all my design decisions as well.
_______________
Johanna Botman
GIS / Assets Officer
Griffith City Council
Ph: 02 6962 8168
From: Jonathan Moules <jonathanmoules at warwickshire.gov.uk>
To: Johanna.Botman at griffith.nsw.gov.au,
Cc: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
Date: 16/10/2013 12:37 AM
Subject: Re: [Qgis-user] Customising QGIS DuFour install - Windows
Hi Johanna,
In Settings -> Options, under the "General" tab you can set the
application font, including size. This seems to carry over to Composer, or
does for me at least.
The second point sounds like a bug - I'd suggest reporting it to the bug
tracker with examples.
Cheers,
Jonathan
Please consider the environment before printing this email notice.
This e-mail, together with any attachments, is for the exclusive and
confidential use of the addressee(s. Confidentiality is not waived if
you are not the intended recipient. Any other distribution, use of,
or reproduction without prior written consent is strictly prohibited.
Views expressed in this e-mail are those of the individual, except
where specifically stated otherwise. If this e-mail has been sent to
you in error, please delete the e-mail completely and immediately from
your system. Although reasonable precautions are taken, Griffith City
Council does not warrant or guarantee this message to be free of errors,
interference,viruses or similar malicious code and does not accept
liability for any consequences to the recipient opening or using this
email or attachments.
This email was scanned and cleared by NetIQ MailMarshal and Norman AV
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
