[Qgis-user] Help running SAGA algorithms
Julian Bogdani
jbogdani at gmail.com
Mon Oct 21 06:09:23 PDT 2013
Hello all,
I'm trying to run saga algorithms (Kriging) on QGIS, MacOS X (10.6.8) (and Win, 7) without success.
I've installed latest QGIS from KyngChaos site.
Saga seems to be installed correctly.
Here is the message I get:
Oooops! The following output layers could not be open
Grid: /Users/jbogdani/Desktop/gis/one.tif
Variance: /Users/jbogdani/Desktop/gis/two.tif
The above files could not be opened, which probably indicates that they were not correctly produced by the executed algorithm
Checking the log information might help you see why those layers were not created as expected
This algorithm requires SAGA to be run. A test to check if SAGA is correctly installed and configured in your system has been performed, with the following result:
SAGA seems to be correctly installed and configured
Thank you
Julian Bogdani
http://bradypus.net
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131021/a5e2ce3e/attachment.html>
