[Qgis-user] Error loading SIP module.
Goyo goyodiaz at gmail.com
Mon Oct 21 09:27:56 PDT 2013
2013/10/21 Nicholas L. Klein-Baer <nklein-baer at humboldt.edu>:
> Hi all,
> I'm having a problem with QGIS 2.0.1 on Ubuntu 13.04 very similar to the one
> described bug 8832. The resolution, however, isn't helping me very much.
>>>>If you want to use a different python/sip/pyqt4 than what is in your
>>>> ubuntu by default, you need to build QGIS yourself against it.
> I'm a little confused by this because I don't think sip was install by
> default: Before I manually installed it I was getting an error saying "no
> module named sip"
> Any ideas on what I should do?
"Default" here means the version provided by Ubuntu in the standard
repositories, as opposed to the EPD version provided by Entough or the
upstream version of sip provided by Riverbank.
Goyo
