[Qgis-user] db-manager (temporary tables)
Andreas Neumann a.neumann at carto.net
Tue Oct 22 04:44:36 PDT 2013
You can load query results in db-manager.
Just create a query in db-manager, select the primary key column and the
geometry column and load it.
Works fine for me.
Andreas
Am 22.10.2013 13:42, schrieb António M. Rodrigues:
> Hi,
> Is there a way to access temporary tables through db-manager?
> From what I get, this is only possible through layer->add postgis layer
> (also not available in the browser panel).
> Thanks,
> António
> Qgis-user mailing list
