[Qgis-user] problem reading csv file (numbers read as strings)
matteo matteo.ghetta at gmail.com
Tue Oct 22 08:18:24 PDT 2013
On 22/10/2013 16:50, Alexandre Neto wrote:
> Well, let's mess things a bit more...
> I have opened your csv using this settings
> <https://dl.dropboxusercontent.com/u/110618644/Capturar.JPG>[1].
> And both coordinates fields were read as integer (because they have no
> decimal part), not texts
Thanks Alexandre..
Till 1.9 release QGIS asked immediately for the CRS. Now you have to
specify it in the properties of the layer you have added. This problem
is solved! :)
But could you try to add a table (csv file) in the map canvas and see if
qgis recognize the numbers as numbers (real or integer, it doesn't matter)?
Thanks
Matteo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131022/44995dd7/attachment.html>
