[Qgis-user] Multiple lines label in QGIS 2.0 print composer using wrap on character?
Lene Fischer lfi at life.ku.dk
Tue Oct 22 09:18:37 PDT 2013
Hi
The trick is:
expression/field    || '\n'  || expression/field
 || is the seperator between fields.
Regards
Lene Fischer
Fra: qgis-user-bounces at lists.osgeo.org [qgis-user-bounces at lists.osgeo.org] på vegne af Alexandre Neto [senhor.neto at gmail.com]
Sendt: 22. oktober 2013 11:09
Til: QGIS User
Emne: [Qgis-user] Multiple lines label in QGIS 2.0 print composer using wrap on character?
Hello all,
Is there a way to create multiple lines label using a wrap on character in QGIS 2.0 print composer? Or this must be done with html rendering?
I'm using atlas generation and the label source is attribute from my coverage layer.
Thanks,
Alexandre Neto
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131022/430476a2/attachment.html>
