[Qgis-user] Installing from OSGEO4W on top of existing GDAL, Python etc
Jürgen E. Fischer
jef at norbit.de
Fri Oct 25 07:07:54 PDT 2013
Hi Sjur,
On Fri, 25. Oct 2013 at 09:30:13 +0000, Sjur Kolberg wrote:
> I already have some libraries installed; GDAL 1.10, NetCDF 4.3, Python 2.7
> etc, and some dependencies of these; built with Visual Studio 2012. Some
> programs I develop are working fine with the current installations, so in
> fear of having a lot of duplicates only causing confusion, I declined to
> install all the dependencies recommended by OSGEO4W. Not a success.
OSGeo4W shouldn't use anything from outside OSGeo4W and doesn't put anything in
PATH or the system apart from the (usual) MSVC runtimes. So installing
everything QGIS depends from OSGeo4W shouldn't cause problems.
But using QGIS with something is wasn't built with might.
> Add/Remove programs does not show any trace of OSGEO4W, and I don't find any
> uninstall script.
Uninstall all packages using the installer and then remove the osgeo4w
directory. Just removing the OSGeo4W directory will leave the desktop icons
and start menu entries around - but otherwise shouldn't do any harm.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS PSC member (RM) IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
