[Qgis-user] Note on bug in Lat/Lon plugin
Mikhail Tchernychev
misha at mail.geometrics.com
Mon Oct 28 14:31:57 PDT 2013
Hello List,
I recently fixed bug in Lat/Lon plugin. Unfortunately fixed version is
not yet approved.
The bug is triggered when new project is used because "projection on the
fly" property
is does not yet exists.
The work round is to go to project settings and enable "projection on
the fly" option before
using Lat/Lon grid plugin. It is needed for plugin anyway.
Alternatively you can replace latlongridlayer.py file with one attached
to this letter.
as well as metadata.txt
Best Regards
Mikhail
LatLonGridLayer - manages and draws an overlay grid.
A QGIS plugin
Overlays a user-definable grid on the map.
begin : 10/01/2013
copyright : (C) 2013 Mikhail Tchernychev
email : mikhail_tchernychev at yahoo.com
* This program is free software; you can redistribute it and/or modify *
* it under the terms of the GNU General Public License as published by *
* the Free Software Foundation; either version 2 of the License, or *
* (at your option) any later version. *
import math
from qgis.core import *
import qgis.utils
from PyQt4.QtGui import QProgressBar
from PyQt4 import QtCore, QtGui, QtXml
from qgis.core import QGis
#from util import *
from PyQt4.QtGui import *
from qgis import core, gui
from PyQt4.QtCore import *
from qgis.gui import QgsMessageBar
from latlongriddialog import LatLonGridDialog
def convertDMS(dms,hemis, type, digits):
if dms > 0:
hemi=hemis[0]
else:
hemi=hemis[1]
dms=-dms
if type == 0:
return '{0:.{dec}F}\xb0{1}'.format(dms, hemi, dec=digits)
d = int(dms)
ms = (dms-d) * 60.0
if type == 1:
return '{0:d}\xb0{1:.{dec}F}\'{2}'.format(d, ms, hemi, dec=digits)
m = int(ms)
s = (ms - m) * 60.0
return '{0:d}\xb0{1}\'{2:.{dec}F}\"{3}'.format(d, m, s, hemi, dec=digits)
class LatLonGridLayer (core.QgsPluginLayer):
LAYER_TYPE = 'LatLonGrid'
_featuremap = {
0: core.QgsField('angle', QtCore.QVariant.Double, 'double', 8, 4),
1: core.QgsField('ordinate', QtCore.QVariant.String, 'string', 32),
2: core.QgsField('alignment', QtCore.QVariant.String, 'string', 8),
3: core.QgsField('offset_x', QtCore.QVariant.Double, 'double', 8, 4),
4: core.QgsField('offset_y', QtCore.QVariant.Double, 'double', 8, 4)
def __init__(self):
core.QgsPluginLayer.__init__(self, LatLonGridLayer.LAYER_TYPE,
'Lat/Lon grid overlay')
self.setValid(True)
self.parent_layer_name = ""
self.parent_layer_id = ""
#dialog
self.dlg = LatLonGridDialog(self)
# connect slot for parent removal
QgsMapLayerRegistry.instance().layerRemoved.connect(self.RemovingParentSlot)
# use dialog boxes or status
self.use_dialogs = False
# grid itlesf
self.ll_grid = []
# step size in decimal degrees
self.step = 0.01
#labels positions
self.labels_S = []
self.labels_N = []
self.labels_W = []
self.labels_E = []
# label to draw
#fields = QgsFields()
#self.label = core.QgsLabel(fields)
#self.label = core.QgsLabel(LatLonGridLayer._featuremap)
#eature.setAttribute(core.QgsLabel.Text, "sasasas")
self.fields = QgsFields()
self.label = QgsLabel(self.fields)
#self.label.labelAttributes().setText('test label')
self.label_features = []
#self.label.labelAttributes().setOffset(-8.66774, 37.08391, 0)
#self.feat.setAttribute(0,'Test Text')
#self.feat.setAttribute('8', -8.66774)
#self.feat.setAttribute('9', 37.08391)
def showDialog(self):
# test if layers are available
nLayers = 0
for name, layer in QgsMapLayerRegistry.instance().mapLayers().iteritems():
if layer.type() == QgsMapLayer.PluginLayer :
continue
nLayers += 1
if nLayers == 0 :
text = "No layers avalaible to create Lat/Lon grid.\nOnly vector and raster layers can be used.\n\n Please add layers to QGIS project!"
if self.use_dialogs :
QtGui.QMessageBox.information(None,'Warning', text, QMessageBox.Ok)
else :
qgis.utils.iface.messageBar().pushMessage("Warning", text, QgsMessageBar.WARNING, 5)
self.setValid(False)
return
# see if on the fly projection is enabled
is_defined = QgsProject.instance().readEntry("SpatialRefSys", "/ProjectionsEnabled")[1]
if not is_defined or int(QgsProject.instance().readEntry("SpatialRefSys", "/ProjectionsEnabled")[0]) == 0:
QtGui.QMessageBox.information(None,'Cannot add lat/lon grid', """Lat/Lon grid alsways uses geograhical coordinates.\n\nPlease enable projection 'on the fly' CRS transformation in project settings!""", QMessageBox.Ok)
else :
qgis.utils.iface.messageBar().pushMessage("Cannot add lat/lon grid", """Lat/Lon grid alsways uses geograhical coordinates.\n\nPlease enable projection 'on the fly' CRS transformation in project settings!""", QgsMessageBar.WARNING, 5)
return
self.get_layer_name_by_id()
self.dlg.show()
result = self.dlg.exec_()
if result == 1:
self.get_layer_id_by_name()
#self.generateGrid()
self.setValid(True)
#self.setLatLonGridCrsAndExtent()
#self.generateLatLonGrid()
self.setCacheImage(None)
self.emit(QtCore.SIGNAL('repaintRequested()'))
else:
def draw(self, renderContext):
if self.CheckLayerExtent() == False :
mapToPixel = renderContext.mapToPixel()
proj = core.QgsProject.instance()
# Default CRS: 3452 == EPSG:4326
srid = proj.readNumEntry('SpatialRefSys', '/ProjectCRSID', 3452)[0]
crs = core.QgsCoordinateReferenceSystem(srid, core.QgsCoordinateReferenceSystem.InternalCrsId)
xform = core.QgsCoordinateTransform(self.crs(), crs)
self.dlg.symbol.startRender(renderContext)
for line in self.ll_grid:
polyline = QtGui.QPolygonF()
for vertex in line:
end = mapToPixel.transform(xform.transform(vertex))
polyline.append(QtCore.QPointF(end.x(), end.y()))
if QGis.QGIS_VERSION_INT < 10800:
self.dlg.symbol.renderPolyline(polyline, renderContext)
else:
self.dlg.symbol.renderPolyline(polyline, None, renderContext)
self.dlg.symbol.stopRender(renderContext)
return True
def drawLabels(self, renderContext):
self.label.setLabelField(QgsLabel.Text,QgsLabel.Text)
self.label.setLabelField(QgsLabel.Angle,QgsLabel.Angle)
self.label.setLabelField(QgsLabel.Alignment,QgsLabel.Alignment)
self.label.setLabelField(QgsLabel.XOffset,QgsLabel.XOffset)
self.label.setLabelField(QgsLabel.YOffset,QgsLabel.YOffset)
for feat in self.label_features :
self.label.renderLabel(renderContext, feat, False)
def writeXml(self, node, doc):
element = node.toElement()
element.setAttribute('type', 'plugin')
element.setAttribute('name', LatLonGridLayer.LAYER_TYPE);
# custom properties
gridElement = doc.createElement('latlongrid')
gridElement.setAttribute('parent_layer', str(self.parent_layer_id))
gridElement.setAttribute('label_format', str(self.dlg.ui.labels_format.currentIndex()))
gridElement.setAttribute('long_spacing', str(self.dlg.ui.long_spacing.value()))
gridElement.setAttribute('lat_spacing', str(self.dlg.ui.lat_spacing.value()))
gridElement.setAttribute('label_north', str(self.dlg.ui.label_north.isChecked()))
gridElement.setAttribute('label_south', str(self.dlg.ui.label_south.isChecked()))
gridElement.setAttribute('label_west', str(self.dlg.ui.label_west.isChecked()))
gridElement.setAttribute('label_east', str(self.dlg.ui.label_east.isChecked()))
gridElement.setAttribute('label_orientation', str(self.dlg.ui.label_orientation.currentIndex()))
node.appendChild(gridElement)
# write font
gridElement = doc.createElement('latlongrid_font')
gridElement.setAttribute('farmily', str(self.dlg.label_attributes.family()))
gridElement.setAttribute('bold', str(self.dlg.label_attributes.bold()))
gridElement.setAttribute('italic', str(self.dlg.label_attributes.italic()))
gridElement.setAttribute('underline', str(self.dlg.label_attributes.underline()))
gridElement.setAttribute('strikeOut', str(self.dlg.label_attributes.strikeOut()))
gridElement.setAttribute('size', str(self.dlg.label_attributes.size()))
gridElement.setAttribute('color', str(self.dlg.label_attributes.color().rgba()))
self.writeSymbology(node, doc)
# write extend
gridElement = doc.createElement('latlongrid_extend')
gridElement.setAttribute('xmin', str(core.QgsPluginLayer.extent(self).xMinimum()))
gridElement.setAttribute('xmax', str(core.QgsPluginLayer.extent(self).xMaximum()))
gridElement.setAttribute('ymin', str(core.QgsPluginLayer.extent(self).yMinimum()))
gridElement.setAttribute('ymax', str(core.QgsPluginLayer.extent(self).yMaximum()))
return True
def writeSymbology(self, node, doc):
symbolElement = core.QgsSymbolLayerV2Utils.saveSymbol('grid_lines', self.dlg.symbol, doc)
node.appendChild(symbolElement)
return True
def readXml(self, node):
gridElement = node.firstChildElement('latlongrid')
if gridElement is not None:
self.parent_layer_id = str(gridElement.attribute('parent_layer'))
self.dlg.ui.labels_format.setCurrentIndex(int(gridElement.attribute('label_format')))
self.dlg.ui.long_spacing.setValue(float(gridElement.attribute('long_spacing')))
self.dlg.ui.lat_spacing.setValue(float(gridElement.attribute('lat_spacing')))
self.dlg.ui.label_north.setChecked('True'== gridElement.attribute('label_north', 'False'))
self.dlg.ui.label_south.setChecked('True'== gridElement.attribute('label_south', 'False'))
self.dlg.ui.label_west.setChecked('True'== gridElement.attribute('label_west', 'False'))
self.dlg.ui.label_east.setChecked('True'== gridElement.attribute('label_east', 'False'))
self.dlg.ui.label_orientation.setCurrentIndex(int(gridElement.attribute('label_orientation')))
gridElement = node.firstChildElement('latlongrid_font')
self.dlg.label_attributes.setFamily(str(gridElement.attribute('farmily')))
self.dlg.label_attributes.setBold('True'== gridElement.attribute('bold', 'False'))
self.dlg.label_attributes.setItalic('True'== gridElement.attribute('italic', 'False'))
self.dlg.label_attributes.setUnderline('True'== gridElement.attribute('underline', 'False'))
self.dlg.label_attributes.setStrikeOut('True'== gridElement.attribute('strikeOut', 'False'))
self.dlg.label_attributes.setSize(float(gridElement.attribute('size')), core.QgsLabelAttributes.PointUnits)
self.dlg.label_attributes.setColor(QtGui.QColor.fromRgba(int(gridElement.attribute('color'))))
self.readSymbology(node)
gridElement = node.firstChildElement('latlongrid_extend')
rect = QgsRectangle();
rect.setXMinimum(float(gridElement.attribute('xmin')))
rect.setXMaximum(float(gridElement.attribute('xmax')))
rect.setYMinimum(float(gridElement.attribute('ymin')))
rect.setYMaximum(float(gridElement.attribute('ymax')))
self.setExtent(rect);
return True
def readSymbology(self, node):
symbolElement = node.firstChildElement('symbol')
if symbolElement is not None and symbolElement.attribute('name') == 'grid_lines':
self.dlg.symbol = core.QgsSymbolLayerV2Utils.loadSymbol(symbolElement)
return True
else:
return False
def get_layer_id_by_name(self) :
if layer.type() == QgsMapLayer.PluginLayer and layer.pluginLayerType() == LatLonGridLayer.LAYER_TYPE :
continue
if layer.name() == self.parent_layer_name :
self.parent_layer_id = layer.id()
break
def get_layer_name_by_id(self) :
continue
if layer.id() == self.parent_layer_id :
self.parent_layer_name = layer.name()
break
def RemovingParentSlot(self, parent_id) :
try:
if parent_id == self.parent_layer_id:
text = "Lat/Lon grid layer '" + self.name() + "'\nwas removed because its parent has been removed!"
else :
QgsMapLayerRegistry.instance().removeMapLayer(self.id())
except:
print "No layer exists..."
def get_parent_layer(self, parent_layer):
continue
parent_layer = layer
return True
return False
def setLatLonGridCrsAndExtent(self) :
layer = QgsMapLayerRegistry.instance().mapLayer(self.parent_layer_id)
# for vector layers
if layer.type() == QgsMapLayer.VectorLayer :
layer.updateExtents()
if layer == None :
text = "Cannot get parent layer for Lat/Lon grid !\nLat/Lon CRS not set!"
return
if layer.crs().geographicFlag() == False: # deal with projected CRS
proj_str = "+proj=longlat +datum=" + layer.crs().ellipsoidAcronym() + " +no_defs"
geo_system = QgsCoordinateReferenceSystem()
geo_system.createFromProj4(proj_str)
core.QgsPluginLayer.setCrs(self, geo_system)
transform = QgsCoordinateTransform(layer.crs(), geo_system)
core.QgsPluginLayer.setExtent(self, transform.transform(layer.extent()))
return
# if parent layer is lat/lon CRS, use it
core.QgsPluginLayer.setCrs(self, layer.crs())
core.QgsPluginLayer.setExtent(self, layer.extent())
def CheckLayerExtent(self) :
# for vector layers
if layer.extent().xMinimum() == core.QgsPluginLayer.extent(self).xMinimum() and \
layer.extent().xMaximum() == core.QgsPluginLayer.extent(self).xMaximum() and \
layer.extent().yMinimum() == core.QgsPluginLayer.extent(self).yMinimum() and \
layer.extent().yMaximum() == core.QgsPluginLayer.extent(self).yMaximum() :
return True
return False
def generateLatLonGrid(self) :
self.ll_grid = []
dx = self.dlg.ui.long_spacing.value()
dy = self.dlg.ui.lat_spacing.value()
x1 = core.QgsPluginLayer.extent(self).xMinimum()/dx
y1 = core.QgsPluginLayer.extent(self).yMinimum()/dy
x2 = core.QgsPluginLayer.extent(self).xMaximum()/dx
y2 = core.QgsPluginLayer.extent(self).yMaximum()/dy
#progressMessageBar = self.iface.messageBar().createMessage("Generating Lat/Lon grid...")
#progress = QProgressBar()
#progress.setMaximum(100)
#progress.setAlignment(Qt.AlignLeft|Qt.AlignVCenter)
#progressMessageBar.layout().addWidget(progress)
#self.iface.messageBar().pushWidget(progressMessageBar, self.iface.messageBar().INFO)
#i_progress = 0;
scale = 1.
# x1, y1 x2, y2 in lat / lon, transate in selected units
if self.dlg.ui.labels_format.currentIndex() == 1 : # minutes
x1 *= 60.
y1 *= 60.
x2 *= 60.
y2 *= 60.
scale = 60.
elif self.dlg.ui.labels_format.currentIndex() == 2: # seconds
x1 *= 3600.
y1 *= 3600.
x2 *= 3600.
y2 *= 3600.
scale = 3600.
x1 = round(x1)
y1 = round(y1)
x2 = round(x2)
y2 = round(y2)
if x2 - x1 > 1000 or y2 - y1 > 1000 :
text = "Too many Lat/Lon lines! Cannot update view!"
else :
qgis.utils.iface.messageBar().pushMessage("Warning", text, QgsMessageBar.WARNING, 10)
return
self.labels_S = []
self.labels_N = []
self.labels_W = []
self.labels_E = []
# horizontal lines
if y1 < scale*core.QgsPluginLayer.extent(self).yMinimum()/dy : y1 += 1
if y2 > scale*core.QgsPluginLayer.extent(self).yMaximum()/dy : y2 -= 1
yt = y1
while yt <= y2 :
line = []
xt1 = core.QgsPluginLayer.extent(self).xMinimum()
i = 1
bContinue = True
line.append(core.QgsPoint(xt1, dy*yt/scale));
self.labels_W.append([xt1, (dy*yt/scale)])
while bContinue:
xt2 = xt1 + self.step * i
if xt2 > core.QgsPluginLayer.extent(self).xMaximum() :
xt2 = core.QgsPluginLayer.extent(self).xMaximum()
bContinue = False
self.labels_E.append([xt2, (dy*yt/scale)])
line.append(core.QgsPoint(xt2, dy*yt/scale));
i += 1
self.ll_grid.append(line)
yt += 1
#i_progress += 1
#progress.setValue(i_progress)
# vertical lines
if x1 < scale*core.QgsPluginLayer.extent(self).xMinimum()/dx : x1 += 1
if x2 > scale*core.QgsPluginLayer.extent(self).xMaximum()/dx : x2 -= 1
xt = x1
while xt <= x2:
line = []
yt1 = core.QgsPluginLayer.extent(self).yMinimum()
i = 1
bContinue = True
line.append(core.QgsPoint(dx*xt/scale, yt1));
self.labels_S.append([(dx*xt/scale), yt1])
while bContinue:
yt2 = yt1 + self.step * i
if yt2 > core.QgsPluginLayer.extent(self).yMaximum() :
yt2 = core.QgsPluginLayer.extent(self).yMaximum()
bContinue = False
self.labels_N.append([(dx*xt/scale), yt2])
line.append(core.QgsPoint(dx*xt/scale, yt2));
i += 1
xt += 1
#self.iface.messageBar().clearWidgets()
self.generateLabels()
def generateLabels(self) :
self.label.labelAttributes().setFamily(self.dlg.label_attributes.family())
self.label.labelAttributes().setBold(self.dlg.label_attributes.bold())
self.label.labelAttributes().setItalic(self.dlg.label_attributes.italic())
self.label.labelAttributes().setUnderline(self.dlg.label_attributes.underline())
self.label.labelAttributes().setStrikeOut(self.dlg.label_attributes.strikeOut())
self.label.labelAttributes().setSize(self.dlg.label_attributes.size(), core.QgsLabelAttributes.PointUnits)
self.label.labelAttributes().setColor(QtGui.QColor.fromRgba(self.dlg.label_attributes.color().rgba()))
x_digits = 0;
a = math.log(float(self.dlg.ui.long_spacing.value()))/math.log(10.)
if a < 0 :
x_digits = int(round(math.fabs(a)))
y_digits = 0;
a = math.log(float(self.dlg.ui.lat_spacing.value()))/math.log(10.)
if a < 0 :
y_digits = int(round(math.fabs(a)))
if self.dlg.ui.label_south.isChecked() :
for pos in self.labels_S :
feat = QgsFeature(fields)
feat.initAttributes(QgsLabel.LabelFieldCount)
feat.setGeometry(QgsGeometry.fromPoint(QgsPoint(pos[0], pos[1])))
if self.dlg.ui.label_orientation.currentIndex() == 0 :
feat.setAttribute(QgsLabel.Angle,90.)
feat.setAttribute(QgsLabel.Alignment, 'right')
feat.setAttribute(QgsLabel.XOffset, -2)
else :
feat.setAttribute(QgsLabel.Angle,0.)
feat.setAttribute(QgsLabel.Alignment, 'center|top')
feat.setAttribute(QgsLabel.Text, convertDMS(pos[0], "SN", self.dlg.ui.labels_format.currentIndex(), x_digits))
self.label_features.append(feat)
if self.dlg.ui.label_north.isChecked() :
for pos in self.labels_N :
feat.setAttribute(QgsLabel.Alignment, 'left')
feat.setAttribute(QgsLabel.XOffset, 2)
else :
feat.setAttribute(QgsLabel.Alignment, 'center|bottom')
feat.setAttribute(QgsLabel.YOffset, 2)
if self.dlg.ui.label_west.isChecked() :
for pos in self.labels_W :
else :
feat.setAttribute(QgsLabel.Text, convertDMS(pos[1], "WE", self.dlg.ui.labels_format.currentIndex(), y_digits))
if self.dlg.ui.label_east.isChecked() :
for pos in self.labels_E :
else :
feat.setAttribute(QgsLabel.Text, convertDMS(pos[1], "WE", self.dlg.ui.labels_format.currentIndex(),y_digits))
# This file contains metadata for your plugin. Beginning
# with version 1.8 this is the preferred way to supply information about a
# plugin. The current method of embedding metadata in __init__.py will
# be supported until version 2.0
# This file should be included when you package your plugin.
# Mandatory items:
[general]
name=LatLonGrid
qgisMinimumVersion=2.0
description=Create Lat/lon grid based on layer extend
version=0.2
author=Mikhail Tchernychev
email=mikhail_tchernychev at yahoo.com
# end of mandatory metadata
# Optional items:
# Uncomment the following line and add your changelog entries:
# changelog=
# tags are comma separated with spaces allowed
tags=
homepage=
tracker=
repository=
# experimental flag
experimental=True
# deprecated flag (applies to the whole plugin, not just a single version
deprecated=False
