[Qgis-user] New Processing version
Victor Olaya volayaf at gmail.com
Wed Oct 30 07:44:34 PDT 2013
That seems to be related to a missing class. That class has been
removed from the plugin, but it seems that the plugin manager tries to
reload it or looks for it, and complains when it cannot find it. The
new version should however, work fine without it.
If you have further problems, I recommend you to remove the old
version and then install Processing (a fresh install instead of an
update).
Hope this helps.
2013/10/30 Saint <zpsantos1 at hotmail.com>:
> Hi Victor,
> Many thanks for the update plugin.
> In my case when I was updating the plugin I have one error saying with the
> following statment: the plugin depends on some components missing on your
> system. You need to instal the following Python Module in order to enable
> it: Algorithm Executor!
> How can I fix this?
> Best Regards and thanks,
> José Santos
> José Santos
> GIS Analyst
> View this message in context: http://osgeo-org.1560.x6.nabble.com/New-Processing-version-tp5086310p5086590.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
