[Qgis-user] Centroid error
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Mon Sep 2 11:39:31 PDT 2013
Hi Paddy,
i doubt that you can set a "tolerance" somewhere.
As a general hint: use functions provided by SEXTANTE-plugin/Processing.
Most of the time, they perform much better than the standard ftools
functions, and you don't litter your project with tons of test-files as
the output is always only temporary.
For centroids, there is a function in SAGA for this.
Besides that, with 17.000 polygons,it's quite likely that there are some
topology errors. Maybe thats also a possible reason for malfunctions (just
guessing).
Greetz
Bernd
Am 01.09.2013, 17:34 Uhr, schrieb Pat Brown <mistyhaven at gmail.com>:
> Hi List,
> I have a layer of around 17000 polygons, for which I want to derive the
> centroid. Using the Vector/Geometry Tools/Polygon Centroid tool the
> process
> progressed to around 45% when this message came up: "Error processing
> specified tolerance. Please choose larger tolerance". Can anybody tell me
> why this occurred and how does one set a larger tolerance?
> Thanks,
> Paddy
Bernd Vogelgesang * Siedlerstrasse 2 * 91083 Baiersdorf * +49-9133-825374
