[Qgis-user] Which font for Delimited Text Layer
silverio abati
chiocciola81 at katamail.com
Fri Sep 6 00:09:52 PDT 2013
Thank you for all!
Chris, your picture of the 1.9 and 2.0 Versions is quite useful (I have the
1.8 version)
The solution proposed by Micha is really simple (and It allowed me to
reflect upon the concept). Obviously it works!!
thanks again,
silverio
2013/9/5 Chris Crook <ccrook at linz.govt.nz>
> Hi Silverio
> Depends which version of QGIS you are using. Version 1.8 does not support
> longitudes and latitudes entered as degrees, minutes, and seconds.
> If you are using the development version 1.9, soon to be released as 2.0
> then it should support this (with your first format). There is a check box
> in the delimited text dialog "DMS coordinates" that you can tick to tell
> QGIS to expect this format.
> The format is quite general - basically it is looking for three numbers
> with something other than numbers between them. So your first format
> should work. Your second won't (nothing between the numbers ) and your
> third won't either (the "." is ambiguous as it could be part of a decimal
> number). As it is written it will take degrees and decimal minutes, or
> degrees, minutes and decimal seconds - so the last format may get
> misinterpreted as degrees and decimal minutes.
> If you are using 1.9/2.0 with the first format, and it is not working,
> could you send me the file and I'll see if I can figure out why
> Thanks
> Chris
> > Date: Thu, 5 Sep 2013 14:11:46 +0200
> > From: silverio abati <chiocciola81 at katamail.com>
> > To: qgis-user at lists.osgeo.org
> > Subject: [Qgis-user] Which font for Delimited Text Layer
> > Message-ID:
> > <CA+jvUu0AQZFixB1AUtfZaLi3uNw3_j=daVsA5Re=HysRzuySUA at ma
> > il.gmail.com>
> > Content-Type: text/plain; charset="iso-8859-1"
> > hello List,
> > I have a little problem to import a layer with the function "delimited
> text
> > layer":
> > I have the coordinates (e.g. 41?44'51'' Lat, 14?18'13'' Long) and I know
> the
> > coordinate reference system: WGS84 UTM33N, EPSG: 32633.
> > the problem is that I don't know which font I have to use in the database
> > (e.g. excel) so QGIS can read them in correct mode (at the end of the
> import
> > process QGIS says me the fields for coordinates are no valid).
> > I tried:
> > 41?44'51''
> > 414451
> > 41.44.51
> > but they don't work
> > thank you very much
> > BEST,
> > silverio
> This message contains information, which is confidential and may be
> subject to legal privilege. If you are not the intended recipient, you must
> not peruse, use, disseminate, distribute or copy this message. If you have
> received this message in error, please notify us immediately (Phone 0800
> 665 463 or info at linz.govt.nz) and destroy the original message. LINZ
> accepts no responsibility for changes to this email, or for any
> attachments, after its transmission from LINZ. Thank You.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130906/3b2163bd/attachment.html>
