[Qgis-user] Saga not working with "In processing" aka sextante
Victor Olaya
volayaf at gmail.com
Fri Sep 6 04:27:36 PDT 2013
hmmm, i do not know if that might be the cause of this problems...but
changing the "enable 2.0.8 compatibility" setting requires restarting
QGIS...
I am going to add a warning for this
2013/9/6 Victor Olaya <volayaf at gmail.com>:
> yes, that is strange. I can use both version in windows, but someone
> has reported problems in windows as well...
> Please, if you find algs that do not work, fill an issue or send an
> email to me, so we can keep track of that
> Thanks!
> 2013/9/6 Werner Macho <werner.macho at gmail.com>:
>> Hi!
>> Is it possible that there is something wrong with packaging?
>> Because I can use saga here without any problems on QGIS 1.8, QGIS 2.0
>> and QGIS master ..
>> Though only saga 2.0.8 installed here and everything compiled by myself ..
>> and I also realised that some algos are working while others does not..
>> maybe that helps finding the problem ..
>> regards
>> Werner
>> On Fri, Sep 6, 2013 at 12:54 PM, Victor Olaya <volayaf at gmail.com> wrote:
>>> Paolo,
>>> I agree with that, we have discussed about it, but in the short term
>>> maybe we need a quicker solution. It seems that now linux users cannot
>>> use SAGA algorithms at all...
>>> 2013/9/6 Paolo Cavallini <cavallini at faunalia.it>:
>>>> -----BEGIN PGP SIGNED MESSAGE-----
>>>> Hash: SHA1
>>>> Il 06/09/2013 12:39, Victor Olaya ha scritto:
>>>>> I am starting to get worried about this and I might take the
>>>>> decision to go back to supporting a single version...
>>>>> Suporting SAGA in linux is becoming a nightmare...
>>>>> Thanks for your help (and patience), everyone!
>>>> IMHO we need a way to support multiple versions of everything, with a
>>>> detection mechanism, and a switch.
>>>> We implemented this for GRASS.
>>>> Probably this will require some duplication of code, but it is just
>>>> impossible to be sure all the sw is aligned across all platforms.
>>>> of course, help and contributions welcome.
>>>> All the best.
>>>> Paolo Cavallini - Faunalia
>>>> www.faunalia.eu
>>>> Full contact details at www.faunalia.eu/pc
>>>> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
>>>> -----BEGIN PGP SIGNATURE-----
>>>> Version: GnuPG v1.4.14 (GNU/Linux)
>>>> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
>>>> iEYEARECAAYFAlIpssIACgkQ/NedwLUzIr4JWwCgtt72pTPyx7Y+hz5lbm9E5WdY
>>>> xS0An1qr2EnByLyt+YTHvUGyXVKKhdEU
>>>> =4KTy
>>>> -----END PGP SIGNATURE-----
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
