[Qgis-user] Can't seem to import qgis.core in OSX 10.8
Larry Shaffer
larrys at dakotacarto.com
Sat Sep 7 10:44:18 PDT 2013
Hi Nick,
Welcome to using QGIS.
In Terminal, you'll want to set the following:
export PYTHONPATH=/Applications/QGIS.app/Contents/Resources/python
Or, when importing from within a Python module, or at Python console's
prompt in Terminal, you can append that path to the Python executable's
sys.path:
import sys
sys.path.append('/Applications/QGIS.app/Contents/Resources/python')
Alternatively, and more to the benefit of understanding PyQGIS, you can use
the Python Console within a running QGIS app, which uses QGIS's embedded
Python executable.
Here are the current docs for the upcoming 2.0 release, though much of it
works fine for 1.8:
http://docs.qgis.org/2.0/html/en/docs/pyqgis_developer_cookbook/
Regards,
Larry
On Sat, Sep 7, 2013 at 11:28 AM, Nick Eubank <nickeubank at gmail.com> wrote:
> Hi All,
> I'm very new to qgis (moving over from Arc), and I'm having trouble
> importing qgis 1.8.0.
> It seems I'm successfully setting the environment variable correctly to
> "/Applications/QGIS.app/Contents/Resources/python" (I can get it to echo
> back), and when I look in that folder I can see "core.so", but I keep
> getting "*ImportError:* 'No module named qgis.core'".
> Any suggestions?
> Thanks for helping the noob.
> Nick
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130907/25246919/attachment.html>
