[Qgis-user] Saga not working with "In processing" aka sextante
matteo
matteo.ghetta at gmail.com
Mon Sep 9 03:04:10 PDT 2013
Il 09/09/2013 11:54, Victor Olaya ha scritto:
> yes, that doesn't include the change
> You can see that it is trying to call centroids to perform the
> test...but it passes a points layer. It should pass a polygon one.
> That was the change i introduced
> When master gets updated, you should get the new code, which should
> perform the test correctly
> Cheers, and thanks again!
Awesome! Thanks!
Matteo
