[Qgis-user] Convert Arc projects (MXD) in QGIS
aperi2007
aperi2007 at gmail.com
Fri Sep 13 12:24:44 PDT 2013
AFAIK the mxd don't host the data.
So the plugin simply take from the mxd the path of the datasets and
write a new qgis project from scratch adding tha same dataset with their
paths.
This is pretty simple for dataset as shapefile.
It work also for data host in arcsde or in geodatabases ?
Thx,
Andrea.
On 13/09/2013 19:56, Steve G wrote:
> I tried this tool several months ago. Unless something has changed with the
> scripting, I can confirm that the tool transfers all of your layers
> displayed in your mxd project to QGIS, however, none of the symbology. I
> guess it's a start if you want to reproduce your mxd project in QGIS, but
> IMHO, the real work is creating the symbology.
> -Steve
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Convert-Arc-projects-MXD-in-QGIS-tp5077193p5077758.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
