[Qgis-user] Error compiling master
Paulo van Breugel
p.vanbreugel at gmail.com
Fri Sep 20 00:39:07 PDT 2013
Hi, I am trying to compile master (QGIS version: 2.1.0 Master 20100) on
Ubuntu 13.04, but getting an error, see command line output below. Any
ideas?
-- QGIS version: 2.1.0 Master (20100)
-- Found GRASS: /usr/local/grass6.4.current/grass-6.4.3svn/ (6.4.3svn)
-- Found Proj: /usr/lib/libproj.so
-- Found GEOS: /usr/lib/libgeos_c.so
-- Found GDAL: /usr/local/gdal1.9/lib/libgdal.so (1.9.2)
-- Found Expat: /usr/lib/x86_64-linux-gnu/libexpat.so
-- Found Spatialindex: /usr/lib/libspatialindex.so
-- Found Qwt: /usr/lib/libqwt.so (5.2.2)
-- Found Sqlite3: /usr/lib/x86_64-linux-gnu/libsqlite3.so
-- Found PostgreSQL: /usr/lib/libpq.so
-- Found SpatiaLite: /usr/lib/libspatialite.so
-- Touch support disabled
-- Found QScintilla2: /usr/lib/libqscintilla2.so (2.7.1)
-- Pedantic compiler settings enabled
-- Found Python executable: /usr/bin/python
-- Found Python version: 2.7.4
-- Found Python library: /usr/lib/libpython2.7.so
-- Found SIP version: 4.14.5
-- Found PyQt4 version: 4.10
-- Found QScintilla2 PyQt4 module: 2.7.1
-- Found GSL: -L/usr/lib -lgsl -lgslcblas -lm
-- Ctest Binary Directory set to:
/home/paulo/Software/spatial/qgis/Quantum-GIS/build-master/output/bin
-- Configuring done
-- Generating done
-- Build files have been written to:
[ 0%] [ 0%] Built target qgis.g.info
[ 5%] [ 5%] Generating qgsversion.h
Built target qgis.d.rast
Built target ui
[ 5%] Built target version
[ 5%] Built target qgis.g.browser
[ 6%] Built target t2tdoc
[ 6%] Built target pyutils
[ 6%] Built target fTools-.-stageinstall
[ 6%] Built target fTools-icons-stageinstall
[ 7%] Built target processing-ui-stageinstall
[ 7%] Built target GdalTools-.-stageinstall
[ 8%] Built target fTools-tools-stageinstall
[ 8%] Built target GdalTools-icons-stageinstall
[ 8%] Built target db_manager-db_plugins_postgis_icons-stageinstall
[ 8%] Built target db_manager-db_plugins_postgis-stageinstall
[ 8%] [ 8%] Built target
db_manager-db_plugins_postgis_plugins_qgis_topoview-stageinstall
Built target fTools-icons_default-stageinstall
[ 8%] Built target
db_manager-db_plugins_postgis_plugins_versioning-stageinstall
[ 8%] Built target db_manager-db_plugins_postgis_plugins-stageinstall
[ 9%] [ 9%] Built target
db_manager-db_plugins_spatialite_icons-stageinstall
Built target GdalTools-tools-stageinstall
[ 9%] Built target
db_manager-db_plugins_postgis_plugins_qgis_topoview_templates-stageinstall
[ 9%] Built target db_manager-db_plugins_spatialite-stageinstall
[ 9%] Built target db_manager-db_plugins-stageinstall
[ 9%] Built target db_manager-ui-stageinstall
[ 9%] Built target processing-._admintools_geoserver-stageinstall
[ 9%] Built target processing-._admintools_httplib2-stageinstall
[ 9%] Built target db_manager-icons-stageinstall
[ 9%] Built target db_manager-.-stageinstall
[ 9%] Built target processing-._algs_mmqgisx-stageinstall
[ 9%] Built target processing-._admintools-stageinstall
[ 9%] Built target processing-._algs_mmqgisx_icons-stageinstall
[ 9%] Built target processing-._commander-stageinstall
[ 9%] Built target processing-._algs-stageinstall
[ 9%] Built target processing-._core-stageinstall
[ 9%] Built target processing-._gdal_scripts-stageinstall
[ 9%] Built target processing-._algs_ftools-stageinstall
[ 9%] Built target processing-._gdal_pyogr-stageinstall
[ 9%] Built target processing-._algs_ftools_icons-stageinstall
[ 9%] Built target processing-grass-stageinstall
[ 9%] Built target processing-grass_ext-stageinstall
[ 9%] Built target processing-._gdal-stageinstall
[ 9%] Built target processing-gui_help-stageinstall
[ 9%] Built target processing-._gdal_icons-stageinstall
[ 9%] Built target processing-._lidar_fusion-stageinstall
[ 9%] Built target processing-._images-stageinstall
[ 9%] Built target processing-._lidar-stageinstall
[ 9%] Built target processing-._lidar_lastools-stageinstall
[ 9%] Built target processing-gui-stageinstall
[ 9%] Built target processing-modeler-stageinstall
[ 9%] Built target processing-._otb_helper-stageinstall
[ 9%] [ 9%] Built target processing-modeler_models-stageinstall
Built target processing-._otb-stageinstall
[ 9%] Built target processing-._outputs-stageinstall
[ 9%] Built target processing-._parameters-stageinstall
[ 9%] Built target processing-r-stageinstall
[ 9%] Built target processing-r_scripts-stageinstall
[ 9%] Built target processing-saga_ext-stageinstall
[ 9%] Built target processing-._otb_description_doc-stageinstall
[ 9%] Built target processing-script-stageinstall
[ 9%] Built target processing-saga-stageinstall
[ 9%] Built target processing-grass_description-stageinstall
[ 9%] Built target processing-._otb_description-stageinstall
[ 9%] Built target processing-script_scripts-stageinstall
[ 9%] Built target processing-tools-stageinstall
[ 9%] Built target processing-taudem-stageinstall
[ 9%] Built target processing-taudem_description-stageinstall
[ 9%] [ 9%] Built target processing-tests-stageinstall
Built target processing-._exampleprovider-stageinstall
[ 9%] Built target processing-.-stageinstall
[ 9%] Built target processing-tests_data-stageinstall
[ 9%] Built target pyconsole
[ 9%] Built target qgis_applicationtestmoc
[ 9%] Built target pyplugin-installer
[ 9%] Built target qgis_atlascompositiontestmoc
[ 9%] [ 9%] Built target qgis_blendmodestestmoc
Built target qgis_clippertestmoc
[ 9%] Built target qgis_composereffectstestmoc
[ 9%] Built target qgis_composerhtmltestmoc
[ 9%] Built target qgis_composerlabeltestmoc
[ 9%] Built target qgis_composermaptestmoc
[ 9%] Built target qgis_composerscalebartestmoc
[ 9%] Built target qgis_composershapestestmoc
[ 9%] Built target qgis_contrastenhancementtestmoc
[ 9%] Built target qgis_coordinatereferencesystemtestmoc
[ 9%] Built target qgis_dataitemtestmoc
[ 9%] Built target qgis_diagramtestmoc
[ 9%] [ 9%] Built target qgis_expressiontestmoc
Built target qgis_distanceareatestmoc
[ 9%] Built target qgis_filewritertestmoc
[ 9%] [ 9%] Built target qgis_maplayertestmoc
Built target qgis_geometrytestmoc
[ 9%] Built target qgis_maprenderertestmoc
[ 9%] [ 9%] Built target qgis_ogcutilstestmoc
Built target qgis_pointtestmoc
[ 9%] Built target qgis_rasterlayertestmoc
[ 9%] Built target qgis_rasterfilewritertestmoc
[ 9%] Built target qgis_rastersublayertestmoc
[ 9%] [ 9%] Built target qgis_rectangletestmoc
Built target qgis_regression1141moc
[ 9%] Built target qgis_regression992moc
[ 9%] [ 9%] Built target qgis_rendererstestmoc
Built target qgis_rulebasedrenderertestmoc
[ 9%] Built target qgis_stylev2testmoc
[ 9%] Built target qgis_vectorlayercachetestmoc
[ 9%] Built target qgis_vectordataprovidertestmoc
[ 9%] Built target qgis_vectorlayertestmoc
[ 9%] Built target qgis_ziplayertestmoc
[ 9%] Built target qgis_dualviewtestmoc
[ 9%] Built target qgis_histogramtestmoc
[ 9%] Built target qgis_projectionissuesmoc
[ 9%] Built target qgis_scalecomboboxmoc
[ 9%] Built target qgis_rubberbandtestmoc
[ 9%] [ 9%] Built target qgis_openstreetmaptestmoc
[ 9%] Built target qgis_zoomtestmoc
Built target qgis_analyzertestmoc
[ 9%] [ 9%] [ 9%] Built target qgis_wcsprovidertestmoc
Built target qgis_zonalstatisticstestmoc
Built target qgis_qgisappclipboardmoc
Scanning dependencies of target qgis_core
[ 9%] Built target processing-saga_description-stageinstall
[ 9%] Built target staged-plugins
[ 9%] Built target staged-plugins-on-build
[ 9%] [ 9%] [ 9%] [ 9%] Building CXX object
src/core/CMakeFiles/qgis_core.dir/qgis.cpp.o
Building CXX object
src/core/CMakeFiles/qgis_core.dir/qgscontexthelp_texts.cpp.o
Building CXX object src/core/CMakeFiles/qgis_core.dir/qgserror.cpp.o
Building CXX object
src/core/CMakeFiles/qgis_core.dir/qgsexpression_texts.cpp.o
Linking CXX shared library ../../output/lib/libqgis_core.so
[ 21%] Built target qgis_core
Linking CXX shared module
../../../output/lib/qgis/plugins/libmemoryprovider.so
Linking CXX shared library ../../../output/lib/libqgis_networkanalysis.so
Linking CXX shared library ../../output/lib/libqgis_analysis.so
[ 22%] Built target qgis_networkanalysis
[ 22%] Built target memoryprovider
Linking CXX shared module ../../../output/lib/qgis/plugins/libogrprovider.so
../../../output/lib/qgis/plugins/libdelimitedtextprovider.so
[ 24%] Built target qgis_analysis
../../../../output/lib/qgis/plugins/libqgissqlanyconnection.so
Linking CXX shared library ../../output/lib/libqgis_gui.so
[ 24%] Built target ogrprovider
Linking CXX shared module ../../../output/lib/qgis/plugins/libgpxprovider.so
[ 25%] Built target delimitedtextprovider
../../../output/lib/qgis/plugins/libgrass_gis.6.4.3svn.so
[ 25%] Built target qgissqlanyconnection
Linking CXX shared library ../../../output/lib/qgis/plugins/libqgisgrass.so
[ 25%] Built target gpxprovider
CMakeFiles/grass_gis.6.4.3svn.dir/qgsgrassgislib.cpp.o: In function
`QgsGrassGisLib::G__gisinit(char const*, char const*)':
qgsgrassgislib.cpp:(.text+0x596): undefined reference to `G_set_gisrc_mode'
qgsgrassgislib.cpp:(.text+0x5a9): undefined reference to `G_setenv'
qgsgrassgislib.cpp:(.text+0x5ae): undefined reference to
`G_suppress_masking'
qgsgrassgislib.cpp:(.text+0x5b3): undefined reference to
`G__init_null_patterns'
qgsgrassgislib.cpp:(.text+0x8b4): undefined reference to `G_get_window'
`QgsGrassGisLib::G_read_fp_range(char const*, char const*, FPRange*)':
qgsgrassgislib.cpp:(.text+0x27ea): undefined reference to `G_init_fp_range'
qgsgrassgislib.cpp:(.text+0x280c): undefined reference to
`G_update_fp_range'
qgsgrassgislib.cpp:(.text+0x282e): undefined reference to
`G_update_fp_range'
`G_read_range':
qgsgrassgislib.cpp:(.text+0x2953): undefined reference to `G_init_range'
qgsgrassgislib.cpp:(.text+0x2977): undefined reference to `G_update_range'
qgsgrassgislib.cpp:(.text+0x299b): undefined reference to `G_update_range'
`QgsGrassGisLib::readRasterRow(int, void*, int, int, bool)':
qgsgrassgislib.cpp:(.text+0x31c7): undefined reference to `G_raster_size'
qgsgrassgislib.cpp:(.text+0x31ec): undefined reference to `G_zero'
qgsgrassgislib.cpp:(.text+0x31fe): undefined reference to `G_raster_size'
qgsgrassgislib.cpp:(.text+0x3223): undefined reference to `G_zero'
qgsgrassgislib.cpp:(.text+0x3235): undefined reference to `G_raster_size'
qgsgrassgislib.cpp:(.text+0x325a): undefined reference to `G_zero'
qgsgrassgislib.cpp:(.text+0x329c): undefined reference to
`G_set_c_null_value'
qgsgrassgislib.cpp:(.text+0x32c5): undefined reference to
`G_set_f_null_value'
qgsgrassgislib.cpp:(.text+0x32ee): undefined reference to
`G_set_d_null_value'
`QgsGrassGisLib::G_get_null_value_row(int, char*, int)':
qgsgrassgislib.cpp:(.text+0x357c): undefined reference to
`G_allocate_f_raster_buf'
qgsgrassgislib.cpp:(.text+0x35d6): undefined reference to
`G_is_f_null_value'
qgsgrassgislib.cpp:(.text+0x360c): undefined reference to `G_free'
`QgsGrassGisLib::putRasterRow(int, void const*, int)':
qgsgrassgislib.cpp:(.text+0x37e3): undefined reference to
`G_is_c_null_value'
qgsgrassgislib.cpp:(.text+0x3812): undefined reference to
`G_is_f_null_value'
qgsgrassgislib.cpp:(.text+0x3841): undefined reference to
`G_is_d_null_value'
`G_read_cats':
qgsgrassgislib.cpp:(.text+0x4ed5): undefined reference to
`G_init_raster_cats'
`G_read_raster_cats':
qgsgrassgislib.cpp:(.text+0x4f03): undefined reference to
`G_fully_qualified_name':
qgsgrassgislib.cpp:(.text+0x4ffc): undefined reference to `G_store'
`G_read_quant':
qgsgrassgislib.cpp:(.text+0x51f8): undefined reference to `G_quant_init'
collect2: error: ld returned 1 exit status
make[2]: *** [output/lib/qgis/plugins/libgrass_gis.6.4.3svn.so.2.1.0]
Error 1
make[1]: *** [src/providers/grass/CMakeFiles/grass_gis.6.4.3svn.dir/all]
Error 2
make[1]: *** Waiting for unfinished jobs....
Linking CXX executable ../../output/bin/crssync
[ 25%] Built target qgisgrass
[ 38%] Built target qgis_gui
[ 38%] Built target crssync
make: *** [all] Error 2
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130920/ede7abc1/attachment.html>
