[Qgis-user] Python console doesnt open in Qgis 2.0
Salvatore Larosa
lrssvtml at gmail.com
Tue Sep 24 02:37:33 PDT 2013
On Tue, Sep 24, 2013 at 11:27 AM, Oware Maungu <oware at appliedgeo.org> wrote:
> Starting qgis from terminal shows the warning below:
> Warning: loading of qt translation failed
> [/usr/share/qt4/translations/qt_en_US]
> The message below is also logged (Log Messages)
> Couldn't load Python support library: Cannot load library
> /usr/lib/qgispython: (/usr/lib/libqgispython.so: cannot open shared object
> file: No such file or directory)
that gives us any chance to solve the problem :-)
> To upgrade qgis to the latest release i did # apt-get install qgis
Can you try to run apt-get install --reinstall python-qgis
python-qgis-common ?
> About QGIS:
> QGIS version 2.0.1-Dufour
> Compiled against Qt4.8.1 Running against Qt4.8.1
> Compiled against GDAL/OGR1.7.3 Running against GDAL/OGR1.7.3
> Compiled against GEOS3.2.2-CAPI-1.6.2 Running against GEOS3.3.8-CAPI-1.7.8
> PostgreSQL Client Version9.1.9 SpatiaLite Version3.1.0-RC2
> QWT Version5.2.2 PROJ.4 Version470
> QScintilla2 Version
> Thanks
> On Tue, Sep 24, 2013 at 12:11 PM, Salvatore Larosa <lrssvtml at gmail.com>wrote:
>> Hi,
>> On Tue, Sep 24, 2013 at 10:25 AM, Oware Maungu <oware at appliedgeo.org>wrote:
>>> Hi all,
>>> I've just upgraded to 2.0.1 from 1.8 through ubuntu sources.
>>> However, the python console doesnt open when I click the Plugins->Python
>>> Console menu item.
>>> Has anyone encountered a similar issue ? Am running xubuntu 12.04, no
>>> error is logged in the terminal.
>> Please could you provide some more info ?
>> Check log messages (at the bottom left) or whether you get some message
>> by running qgis from shell.
>> Best Regards,
>> -SL
>>> Thanks
>>> Oware Maungu
>>> Geospatial Developer | Applied Geomatics <http://appliedgeo.org>
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Salvatore Larosa
>> linkedIn: http://linkedin.com/in/larosasalvatore
>> twitter: @lrssvt
>> skype: s.larosa
>> IRC: lrssvt on freenode
> Oware Maungu
Salvatore Larosa
twitter: @lrssvt
skype: s.larosa
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130924/e7bbea27/attachment.html>
