[Qgis-user] Oracle - QGIS connection
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Tue Sep 24 08:00:05 PDT 2013
Hi List,
I've done a lot more dabbling and it simply refuses to work. I've now got
to the point where I've installed the Administrator install of the Oracle
client. Both QGIS and the client are 32bit. But no matter what I keep
getting the Ora-12154 error.
If I try tnsping, it can resolve the name just fine, so I'm not clear why
it is failing with QGIS.
I don't remember what I did previously to get it working but I'm sure it
wasn't anything like this much trouble.
Anyone?
Thanks,
Jonathan
On 23 September 2013 12:56, Jonathan Moules <
jonathanmoules at warwickshire.gov.uk> wrote:
> Hi List,
> This is happening in 2.0.1 too. As other things can connect to the
> database from this machine I have to guess that it is a QGIS thing. I know
> it worked previously but doesn't seem to any more.
> Does it work for other folks? What are you entering into the parameters?
> Thanks,
> Jonathan
> On 28 August 2013 14:33, Jonathan Moules <
>> Anyone?
>> I'm using QGIS weekly build d61cb25 on windows 7.
>> Thanks,
>> Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130924/fed04e0f/attachment.html>
