[Qgis-user] Matplotlib not found with Qgis 2.0.1-1 OS X
Kurt Springs
ferret_bard at mac.com
Tue Sep 24 14:33:25 PDT 2013
Thanks William,
For the most part your suggestions did it. The only problem still there is Processing. It claims to be installed at /Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing). It is working fine on my Lion Machine. As before, I have no way to uninstall or reinstall it. It is telling me that pcopg2 is missing. I tried to use easy_install to install it but it said got the following error:
unable to execute clang: No such file or directory
error: Setup script exited with error: command 'clang' failed with exit status 1
Not sure what that meant.
Like I said, it's fine on my old MacPro with Lion.
Any ideas?
Kurt
On Sep 24, 2013, at 4:27 PM, William Kyngesburye wrote:
> Install my matplotlib package. When you do that, make sure to read the readme - I discovered the pyparsing requirement at the last minute of packaging, so you need to install it in the Terminal.
> For the plugins, you may have leftovers from a previous 2.0 nightly dev build, the Mac installer sometimes doesn't remove old files. Try deleting QGIS from your Applications folder and reinstall.
> On Sep 24, 2013, at 2:17 PM, Kurt Springs wrote:
>> Hi,
>> I recently upgraded Qgis to William Kyngeburye's 2.0.1-1. It is telling me "Could not find matplotlib module. Make sure matplotlib is installed." I get this message on both my MacPro running OS X Lion and my MacBook Pro running Mountain Lion. Is there a simple fix for this?
>> Also, on my 13 inch MacBook Pro, It is telling me I have four invalid plugins: mapserver_export, osm, plugin_installer, and Processing. When I click on them, all of the three buttons (Upgrade all, Uninstall plugin, and Reinstall plugin) are greyed, so I can't just uninstall them. Is there anything I can, or should, do with them? It gives me a path through the QGIS.app package, but I don't want to delete something and have it crash the program.
>> Thanks,
>> Kurt
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "This is a question about the past, is it? ... How can I tell that the past isn't a fiction designed to account for the discrepancy between my immediate physical sensations and my state of mind?"
> - The Ruler of the Universe
