[Qgis-user] Problems with Grass integration
Andreas Neumann
a.neumann at carto.net
Wed Sep 25 06:06:59 PDT 2013
It is a known-issue. GRASS and SAGA integration (esp. in Processing) is
broken if you use the standalone installer.
It should work fine if you use the OSGeo4W installer - see
http://trac.osgeo.org/osgeo4w/
So if you can wait, there will be an updated standalone installer, if
you need it more quickly, then please use the OSGeo4W installer. GRASS
integration should work fine with this one. You will have to install the
QGIS GRASS plugin in the Libraries section, next to QGIS.
Andreas
Am 25.09.2013 14:58, schrieb Hebert Guilherme de Azevedo:
> Hi,
> i'm installed the new stable version of qgis in my computer. In general his
> work's fine, but i can't use the Grass functions and the Grass tools isn't
> enabled. Anyone have a similar trouble? Know how i may solve this?
> Best regards
> Qgis-user mailing list
