[Qgis-user] Qgis 2.0 : no ECW support
Nathan Woodrow
madmanwoo at gmail.com
Thu Sep 26 06:11:27 PDT 2013
Ok, so the main thing here is getting 32bit OSGeo4W updated to GDAL 1.10 in
order to use ECW (plus all the other cool stuff).
Is there a reason it's not on 1.10 and could that be done? Not knowing the
GDAL update process.
I just know that missing ECW support will be a issue for a lot of clients
of mine and having support out of the box would be ideal if it can be done.
- Nathan
On Thu, Sep 26, 2013 at 10:56 PM, Jürgen E. <jef at norbit.de> wrote:
> Hi Nathan,
> On Thu, 26. Sep 2013 at 22:13:12 +1000, Nathan Woodrow wrote:
> > What is the reason for the 32bit and 64bit using different GDAL versions?
> > This seems bad from a consistency platform standpoint.
> I did the complete 64bit build of osgeo4w and for 32bit I used what OSGeo4W
> had at that point.
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden
> http://www.norbit.de
> QGIS PSC member (RM) IRC: jef on FreeNode
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130926/876fe76d/attachment.html>
