[Qgis-user] No python in 2.0?
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Thu Sep 26 09:41:56 PDT 2013
I don't know about the Linux version, but it 2.0.1 certainly includes it in
the Windows install - Python 2.7.
Maybe try wiping it entirely?
On 25 September 2013 14:35, dsierig <david.sierig at gmail.com> wrote:
> Hello,
> I just updated from 1.8 to 2.0 from official qgis repositories but now
> everytime I run qgis I get an error at startup:
> No se pudo cargar el complemento 'processing? de ['/usr/share/qgis/python',
> '/home/user/.qgis2/python', '/home/user/.qgis2/python/plugins',
> '/usr/share/qgis/python/plugins',
> '/usr/local/lib/python2.6/dist-packages/openpyxl-1.6.2-py2.6.egg',
> '/usr/lib/python2.6', '/usr/lib/python2.6/plat-linux2',
> '/usr/lib/python2.6/lib-tk', '/usr/lib/python2.6/lib-old',
> '/usr/lib/python2.6/lib-dynload', '/usr/lib/python2.6/dist-packages',
> '/usr/lib/python2.6/dist-packages/PIL',
> '/usr/lib/python2.6/dist-packages/gst-0.10',
> '/usr/lib/pymodules/python2.6',
> '/usr/lib/python2.6/dist-packages/gtk-2.0',
> '/usr/lib/pymodules/python2.6/gtk-2.0',
> '/usr/lib/python2.6/dist-packages/wx-2.8-gtk2-unicode',
> '/usr/local/lib/python2.6/dist-packages',
> '/usr/share/qgis/python/plugins/fTools/tools']
> Traceback (most recent call last):
> File "/usr/lib/python2.6/dist-packages/qgis/utils.py", line 182, in
> loadPlugin
> __import__(packageName)
> File "/usr/lib/python2.6/dist-packages/qgis/utils.py", line 453, in
> _import
> mod = _builtin_import(name, globals, locals, fromlist, level)
> File "/usr/share/qgis/python/plugins/processing/__init__.py", line 20, in
> from processing.tools.general import runalg, runandload, alghelp,
> alglist, algoptions, load, extent, getobject
> _import
> File "/usr/share/qgis/python/plugins/processing/tools/general.py", line
> 29, in
> from processing.core.Processing import Processing
> _import
> File "/usr/share/qgis/python/plugins/processing/core/Processing.py", line
> 44, in
> from processing.grass.GrassAlgorithmProvider import
> _import
> File
> "/usr/share/qgis/python/plugins/processing/grass/GrassAlgorithmProvider.py",
> line 34, in
> from processing.grass.GrassAlgorithm import GrassAlgorithm
> _import
> File "/usr/share/qgis/python/plugins/processing/grass/GrassAlgorithm.py",
> line 31, in
> import importlib
> _import
> ImportError: No module named importlib
> Versión de Python:
> 2.6.5 (r265:79063, Oct 1 2012, 22:19:00)
> [GCC 4.4.3]
> Versión de QGIS:
> 2.0.1-Dufour Dufour, exported
> Ruta de Python: ['/usr/share/qgis/python', '/home/user/.qgis2/python',
> '/home/user/.qgis2/python/plugins', '/usr/share/qgis/python/plugins',
> Ocurrió un error durante la ejecución del siguiente código:
> pyplugin_installer.initPluginInstaller()
> File "", line 1, in
> File "/usr/share/qgis/python/pyplugin_installer/installer.py", line 43,
> in
> initPluginInstaller
> pluginInstaller = QgsPluginInstaller()
> File "/usr/share/qgis/python/pyplugin_installer/installer.py", line 58,
> in
> __init__
> repositories.load()
> File "/usr/share/qgis/python/pyplugin_installer/installer_data.py", line
> 329, in load
> url = settings.value(key+"/url", "", type=unicode)
> TypeError: QSettings.value(QString, QVariant defaultValue=QVariant()):
> 'type' is not a valid keyword argument
> Versión de Python:
> [GCC 4.4.3]
> Versión de QGIS:
> 2.0.1-Dufour 'Dufour', exported
> Ruta de Python:
> and I get no python support. Here's some additional data
> Versión de QGIS 2.0.1-Dufour
> Revisión del código de QGIS exported
> Compilado contra Qt 4.6.2
> Ejecutándose contra Qt 4.6.2
> Compilado contra GDAL/OGR 1.6.3
> Ejecutándose contra GDAL/OGR 1.6.3
> Compilado contra GEOS 3.1.0-CAPI-1.5.0
> Ejecutándose contra GEOS 3.3.8-CAPI-1.7.8
> Versión del cliente PostgreSQL 8.4.17
> Versión de SpatiaLite 2.4.0
> Versión de QWT 5.2.0 Versión de PROJ.4 470
> Versión de QScintilla2
> I already tried reinstalling, using ubuntu and nightly repositories with no
> changes.
> Thanks in advance
> http://osgeo-org.1560.x6.nabble.com/No-python-in-2-0-tp5079890.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130926/718c337e/attachment.html>
