[Qgis-user] UI - Double clicking a layer to add it
    Larry Shaffer
    larrys at dakotacarto.com
    Thu Sep 26 10:10:26 PDT 2013
Hi Jonathan,
On Thu, Sep 26, 2013 at 10:19 AM, Jonathan Moules <
jonathanmoules at warwickshire.gov.uk> wrote:
> Hi List,
>   I've noted some inconsistency in what happens when you double click a
> layer in an effort to add it to QGIS.
> One of several possible things happens:
> Add Vector Layer:
>  - Double clicking a file closes the "Open an OGR supported Vector Layer"
> dialog but keeps open the "Add vector layer" dialog.
> Add Raster Layer:
>  - Double clicking a raster closes the dialog and adds the file
> immediately to QGIS.
> Add Oracle / SpatiaLite tables (maybe the other databases too?)
>  - Double clicking a table brings up a "Query Builder" for that table.
> Add WMS and Add WCS
>  - Double clicking does nothing.
> Add WFS
>  - Opens up "Expression string builder" dialog
> To me at least this is very wrong. They should all behave in the exact
> same way when I double click something. Personally I'd say the raster way
> is the correct one - that's how all other applications work when I double
> click something to add, be it a GIS or a text editor or anything.
> I appreciate why opening query/expression builders may be useful, but I
> don't think it should be the default action on double-clicking.
> Does anyone else have an opinion on this?
Yes, this is inconsistent and needs addressed. Please create a new bug
issue ticket [0], if one does not already exist.
Thank you for reporting on this.
[0] http://hub.qgis.org/wiki/quantum-gis/Bugreports
Regards,
Larry
> Cheers,
> Jonathan
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130926/10e926a7/attachment.html>
