[Qgis-user] Modis projection (and not MERIS projection)
Alex Mandel
tech_dev at wildintellect.com
Fri Sep 27 11:55:32 PDT 2013
On 09/27/2013 03:28 AM, Giacomo Fontanelli wrote:
> Hello everybody
> I apologize because I have to point out two mistakes I made yesterday in my
> first mail called "MERIS projection" (it was late night and I was almost
> sleeping).
> The first mistake is that I work with MODIS and not MERIS.
> The second mistake is that the correct EPSG code for the MODIS projection
> is 6842, as shown in
> http://spatialreference.org/ref/sr-org/modis-sinusoidal/.
> EPSG:6842 is not available in QGIS 2.0, but there is EPSG:53008 (Sinusoidal
> spheric) that is almost the same
> EPSG:6842 = +proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6371007.181 +b=6371007.181
> +units=m +no_defs
> EPSG:53008= +proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6371007 +b=6371007
> +units=m +no_defs
> At home I still have QGIS 1.8 and I uploaded the new CRS
> By now I am in my office and I'm not able to save my custom CRS (EPSG:6842)
> because the 2.0 version doesn't have the button "save" in the "custom CRS"
> but only "OK".
> Any suggestion?
> Thank you
The new Add CRS is a little buggy. Here's how to make it work:
Hit Add CRS,
it will add a blank CRS to the list, select it,
now enter a name and custom proj line
Hit Add CRS again
This time it will be placed in the list above
You will probably end up with an extra blank line which can now be deleted.
If you hit just enter data and hit Add CRS your custom one vanishes.
Once it's in the list, you can exit the dialog and it will be available
for use. You are correct the Save button no longer exists.
Thanks,
Alex
