[Qgis-user] qtiles plugin
Alexander Bruy
alexander.bruy at gmail.com
Mon Sep 30 05:19:04 PDT 2013
yes QTiles plugin works fine here with both QGIS 2.1
and QGIS 2.0.1.
If you download sources from GitHub, you should remenber
that this is sources, not ready-to-use plugin and you should
perform all necessary operations (compiling resources,
building translations and ui) by yourself. Casual users should
install plugin from repository.
Hope this helps
2013/9/30 daniel <idnael at gmail.com>:
> I want to generate tiles from a QGIS project, to be used in a mobile
> application.
> The QTiles plugin should be apropriate, but although it is listed in
> plugins.qgis.org/plugins, it is not in the qgis module management
> window.
> I tried to download source code from GitHub, but it gives this compile
> error - """gcc: warning: tilingthread.py: linker input file unused
> because linking not done""" - I think it is related with qt version
> numbers...
> So I ask: anyone has QTiles working ?
> (I have QGis 2.0.1, system is Ubuntu 13.04)
> Qgis-user mailing list
Alexander Bruy
