[Qgis-user] Raster calculator question
Andreas Neumann
a.neumann at carto.net
Thu Apr 24 06:25:08 PDT 2014
Hi Carlos,
Thanks a lot. This works fine.
Seems I first have to get used to the raster calculator syntax. Would be
great if it would use the expression editor as is used almost everywhere
else.
Andreas
Am 24.04.2014 12:57, schrieb Carlos Cerdán:
> Hi Andreas:
> Yes, it always evaluates to true because of "OR" condition , so try:
> (lake_mask > 0) * lake_mask + (lake_mask<=0)*dtm
> Good luck
> Carlos
> 2014-04-24 1:53 GMT-05:00 Andreas Neumann <a.neumann at carto.net>:
>> Hi,
>> I have a hard time understanding the raster calculator syntax.
>> I would like to merge two rasters: DTM and lake mask. Let's call the one
>> dtm and the other lake_mask.
>> When the lake_mask has a value > 0 then I would like to take the value
>> of the lake_mask, otherwise the value of the dtm.
>> What would an appropriate syntax look like?
>> I tried something along
>> ((lake_mask > 0) * lake_mask) OR dtm
>> But all I get in the resulting grid are values of 1. I guess it is
>> because it always evaluates to true?
>> Thanks for your help.
>> Andreas
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
