[Qgis-user] Centroid of polygon
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Mon Aug 4 09:28:48 PDT 2014
Hi list,
Quick question, how do you use the Field Calculator to get the centroid as
an attribute? I'm aware of this question answer:
http://gis.stackexchange.com/questions/11705/using-field-calculator-in-qgis-to-update-columns-with-centroid-coordinates
- but want to do it using just the field calculator.
I see under "Geometry" that there's a "centroid" function, but can't figure
out how to use it for this purpose.
Suggestions welcome.
Thanks,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain confidential, sensitive or personal information and should be
handled accordingly. Unless you are the named addressee (or authorised to
receive it for the addressee) you may not copy or use it, or disclose it to
anyone else. If you have received this transmission in error please notify
the sender immediately. All email traffic sent to or from us, including
without limitation all GCSX traffic, may be subject to recording and/or
monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140804/98523408/attachment.html>
