[Qgis-user] Geocoding Plugin
Sasa Sullivan
sasssaa at gmail.com
Wed Aug 6 15:23:25 PDT 2014
Hi All,
I was able to install the MMQGIS plugin okay (Thank you) but getting an
error message after trying to geocode my list, this file appears in the
tutorial and I don't see anything that tells me to do anything about it
there, so I am guessing it is a file present in QGIS or I put it there when
I installed the plugin, I don't know:
Failure Opening: C:\PROGRA~1\QGISCH~1\bin/notfound.csv
Am I suppose to create this file?
Sasa
The tutorial:
[1]
http://www.digital-geography.com/qgis-tutorial-webmap-creation-qgis-qgis2leaf-and-mmqgis
On Wed, Aug 6, 2014 at 5:50 AM, Nikos Alexandris <nik at nikosalexandris.net>
wrote:
> On 06.08.2014 10:41, Patricio Soriano wrote:
>> Hi Sasa
>> You can use the geocoding tool in MMQGIS pluging.
>> Here an example [1]
>> [1]
> I gave it a quick try using a csv with 1000+ records. Got an error message
> back (in the end of the geocoding process, read below) and an empty
> Shapefile.
> QGIS installed via the rion overlay in Funtoo.
> Nikos
> An error has occured while executing Python code:
> Traceback (most recent call last):
> File "/home/nik/.qgis2/python/plugins/mmqgis/mmqgis_dialogs.py", line
> 1168, in run
> shapefilename, notfoundfile, fields, service, 1)
> File "/home/nik/.qgis2/python/plugins/mmqgis/mmqgis_library.py", line
> 1749, in mmqgis_geocode_web_service
> notwriter.writerow(row)
> Error: need to escape, but no escapechar set
> Python version:
> 2.7.8 (default, Jul 6 2014, 15:56:50)
> [GCC 4.8.2]
> QGIS version:
> 2.2.0-Valmiera Valmiera, exported
> Python path: ['/usr/share/qgis/python/plugins/processing',
> '/home/nik/.qgis2/python/plugins/GeoCoding', '/usr/share/qgis/python',
> u'/home/nik/.qgis2/python', u'/home/nik/.qgis2/python/plugins',
> '/usr/share/qgis/python/plugins', '/osgeo/grass70/dist.x86_64-unknown-linux-gnu/etc/python',
> '/home/nik', '/usr/lib64/python27.zip', '/usr/lib64/python2.7',
> '/usr/lib64/python2.7/plat-linux2', '/usr/lib64/python2.7/lib-tk',
> '/usr/lib64/python2.7/lib-old', '/usr/lib64/python2.7/lib-dynload',
> '/usr/lib64/python2.7/site-packages', '/usr/lib64/python2.7/site-packages/geos',
> '/usr/lib64/python2.7/site-packages/gtk-2.0', '/usr/lib64/python2.7/site-packages/wx-3.0-gtk2',
> '/usr/share/qgis/python', '/home/nik/.qgis2/python/plugins/mmqgis/forms',
> '/usr/share/qgis/python/plugins/fTools/tools', '/geo/projects']
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140806/6c885c65/attachment.html>
